I'm running a Raspberry Pi Zero W 24/7 as a headless server - no screen, mouse or keyboard access. I'm using the latest cut of Stretch. It connects to the internet via wifi - doesn't need bluetooth.
What services can I drop from systemctl to get this as lean as possible? secondly, what's the best to drop services? systemctl disable? mask? other?
Trying to get a smooth reliable server - that can be rebooted back to an up and running state quickly & reliably.
TIA
Re: RPIzW Stretch 24/7 running
just dont start services your not employing.
whats currently configured to start up?
a little googleing should reveal whats what if you dont recognise the daemons running
fwiw my own headless pi-0-w server runs the full desktop version of stretch not the lite version, and hosts a mqtt broker web server docker and a couple of servers as well as node red.. its not slow restarting imho.. but i rarely use its resources directly beyond the odd terminal session to update and a couple of the hosted web interfaces.
Assuming that you are actually running "lite" not the desktop version, there really isn't much to turn off. Maybe avahi if that's running.
Add "dtoverlay=pi3-disable-bt" to your /boot/config.txt to make sure bluetooth is disabled. Yes "pi3" on the zero.
- Contact: AOL
You didn't mention what you intended running, however I would echo what BeauSlim said, there is not a lot of fat that I have found in the lite image.
I have a ZeroW running Apache, its crude I know but a reboot took about 50 seconds until SSH was back up…
HTOP shows me using about 60Mb Ram, with me connected...
I have had a play around with this in the past, could be handy for you
https://dietpi.com/dietpi-software.html
13:21:31.756 The SSH2 session has terminated with error.
13:22:19.971 Connection established.
I’m running a number of continuously running python scripts doing various tasks.
Thank you for the feedback - this is very reassuring.
