KDMcM
Splash Screen
Wed Nov 14, 2018 5:43 pm
I use a Raspberry Pi for a control application. It doesn't run an X interface. My script (Python) runs automatically at boot using the systemctl method.
The machine's job is to display some measurements on an LCD screen, but it doesn't do anything until the Pi OS has finished booting. I understand the need for this: there are certain things the computer simply cannot do before the boot process is finished.
How can I find out what operations the machine is capable of at various stages of its boot process? More specifically, is it possible for me to program the GPIO ports or execute my Python script before the OS has finished booting?
Even more specifically, I wish to display a splash screen on the LCD indicating that the OS is booting and that the measurements will start in the next 20 or 30 seconds.
If I even had a few keywords I could Google it would be helpful. Part of my struggle is not knowing what the question is!!!
Thanks.
Aydan
Re: Splash Screen
Thu Nov 15, 2018 1:49 pm
Re: Splash Screen
Thu Nov 15, 2018 2:24 pm
And this may help with GPIO settings on boot
https://www.raspberrypi.org/documentati ... xt/gpio.md
tqhien
Re: Splash Screen
Thu Nov 15, 2018 3:19 pm
I would go to Linux Embedded or build a custom Linux Kernel with buildroot : you keep only what you need, no extra module.
For splash screen, use this link that explain how to quickly show a splash screen : https://bootlin.com/blog/super-fast-linux-splashscreen/
You can start your app in 10 seconds, Python loading libraries take 5 more seconds...
DarkElvenAngel
Re: Splash Screen
Wed Nov 21, 2018 2:54 am
I have a similar setup I've used this guide for a initrd boot splash. You need to install busybox and lzop's maximum compression is 6 not 9 like listed in The guild unless you compile it yourself.
The problem with using an initrd.img is kernel updates seem to break it.
Return to “Advanced users”
