I have a monitor which accepts 4-bit TTL CGA Only. Does anyone know if there is a way to directly output 4-bit TTL from the Raspberry Pi?
I know that there exists VGA-CGA converters, but it would be quite difficult to implement in the intended setup. I am looking for a way to output CGA directly from the Pi.
Thanks,
Re: CGA Output from GERT666 (or other GPIO connection)
First problem is that RPis do not produce TTL signals. Connecting a RPI GPIO directly to a true TTL input is liable to permanently damage the RPi.
Anything is possible,
A level shifter is needed to take the 3.3v logic of the pi to 5v then you have the 4 signals for colour Red Green Blue Intensity, then the sync signals Vsync, Hsync
You'd need to set the resolution to a maximum of 640x200
You most likely won't get true CGA out but 8 or 16(if you can figure out how to drive the Intensity correctly) colour text mode should work.
I wish I still had my CGA monitor I could test that out.
Good luck
Good luck
Thanks for the ideas.DarkElvenAngel wrote: ↑Wed Nov 21, 2018 3:13 amAnything is possible,
Good luck
So I'll have to build my own circuit to drive the monitor. It'll be basically building a vga to cga adapter into the GPIO header as an output device. I suppose I could buy an adapter and reverse engineer it.
Sorta hoping someone else would have done something like this already. lol
Best,
How is it that people, this week, are looking for the same solution I'm looking for.
I have found the GBS 8100 which converters from VGA to 15k RGBS. I'm not sure if that will work on a CGA monitor, like a IBM 5153, though.
My idea/project is to fill an empty IBM 5150 case with a RPi and any necessary support hardware, to make a "sleeper PC". Not too sure if it's possible to get the 5153 CGA monitor to work though.
i would be a little suspicious if the output would support a TTL CGA input, but who knows? The problem is those amazon converts don't really offer much in the way of support
the 5153 does not have a composite input either, so far as i can tell? which would mean you can't take advantage of programs that use color artifacting. if that isn't a concern, i would focus on running the monitor in EGA mode, which is 16 color 320x200. in my opinion, this is the optimal mode of the 5153 and looks pretty bad-ass.
here's an article with a wiring diagram for the input cable:
http://worldphaco.com/uploads/INCREASIN ... O_AUTO.pdf
if you also want to play older stuff that uses artifact colors in NTSC mode, you may want to use something else like a commodore monitor; or at least check the wiring diagram more thoroughly to see if the db9 connector can accept a composite input. (maybe i missed it)
i'm using a SONY PVM which does both
Ok. I'm bumping this because I ran into a roadblock.
None of the VGA to CGA converters I can find out there actually produce RGBI.
Does anyone know of a way to get 4 bit RGBI out of the pi's GPIO header?
If that's impossible, a true VGA to CGA (RGBI) converter?
I'd like to bump this. Has anyone been able to get RBGI output? I'm trying to get an IBM 5153 CGA monitor working with a Raspberry Pi.
Re: 4-bit digital CGA Output from GERT666 (or other GPIO connection)
Some ideas...
Use 4 of 18 bits + sync from VGA666 pins (without connecting a vga666) via a level converter. Set 8-bit framebuffer with such a palette that first 16 colors of it will drive these 4 selected bits as a CGA monitor needs. I don't know if RPi will allow to set a video mode with 7.14 MHz pixel clock
- you will have to set such a resolution in config.txt
Or maybe get a microcontroller, drive a monitor using it and connect the microcontroller to the RPi via UART.
