marcelo_544
Manufacture a custom Rasp at large scale
Mon Nov 12, 2018 6:51 pm
Hello Rasp fellows:
Anyone knows if is there a company that can manufacture a custom Rasp at large scale >1000?.
For example, I do not need the ethernet port and some other HW. On the other hand I need the board has the custom OS and certificate pre installed.
thank you in advance.
marcelo
Re: Manufacture a custom Rasp at large scale
Tue Nov 13, 2018 9:51 am
Farnell have a custom Pi building service.
https://www.element14.com/community/doc ... on-service
Burngate
Tue Nov 13, 2018 9:52 am
Their MOQ is 5000, slightly more than your 1000, but I'm sure you can cope.
I'm not quite sure what you mean by
. Perhaps you could elucidate.
ejolson
Wed Nov 14, 2018 3:31 am
Hello Rasp fellows:
marcelo
Welcome to the forum! A custom manufactured board, even if it only means leaving a few components out during assembly, will likely not reduce costs. If the goal is to have a custom OS and other things installed, all you need is an SD card duplicator and someone to manage the packaging. It may still be worth contacting Farnell for volume pricing either way.
W. H. Heydt
Wed Nov 14, 2018 4:20 am
Perhaps the OP should be looking at the Compute Module line and designing a custom carrier board with only what he needs exposed on.
HawaiianPi
Wed Nov 14, 2018 7:59 pm
... On the other hand I need the board has the custom OS and certificate pre installed.
There is no on-board storage for an OS on the consumer Raspberry Pi hardware. Everything is on the SD card.
The Compute Module 3 is available with on-board eMMC, which can be flashed with an OS, but the CM3 will require a custom carrier board for power and I/O connections.
Imperf3kt
Wed Nov 14, 2018 8:08 pm
Unfortunately, if our OP wishes to install Raspbian, it will not fit on the CM3. They'll either have to get the NEC 16GB version, or get the CM3L and add their own eMMC
Google is ubiquitous - learn to use it!
https://opensource.com/life/16/10/how-ask-technical-questions
HawaiianPi
Wed Nov 14, 2018 8:10 pm
Unfortunately, if our OP wishes to install Raspbian, it will not fit on the CM3. They'll either have to get the NEC 16GB version, or get the CM3L and add their own EMMC
Raspbian Lite would fit, besides, the OP said custom OS (no mention of Raspbian).
Imperf3kt
Wed Nov 14, 2018 9:01 pm
Most of the time I see somebody mention a "custom OS", they simply mean they customised their Raspbian install, installed some software or made some config.txt edits or cron jobs.
Burngate
Thu Nov 15, 2018 9:45 am
... but what does he mean by "certificate" ?
Thu Nov 15, 2018 9:59 am
I suspect we will never know, since he has not reposted since the first one.
Imperf3kt
Thu Nov 15, 2018 9:24 pm
I would assume this is in reference to WiFi compliance.
Return to “Advanced users”
