meminoglu
How can i run 2 python instance which has infinity loop at start up
Sat Nov 10, 2018 3:27 pm
I need to run 2 python instance at run time. I have edited /etc/rc.local file but it doesnt work, because they don't return anything, and i don't want to return it. Because one of the my file is flask file, which is web service, it must run all the time, another is, mifare card reader program (MFRC522-python/Read.py) it has while loop so, it never returns..
i need both files run at start up. i edited start up like (/etc/rc.local)
sudo python /home/pi/MFRC522-python/Read.py & sudo python /home/pi/Flask/Webservis.py
When i try this, web servis run, Read.py doesn't, when i tried other variation
sudo python /home/pi/Flask/Webservis.py & sudo python /home/pi/MFRC522-python/Read.py
Web Servis stops, Read.py is running. How can i solve this problem?
thagrol
Re: How can i run 2 python instance which has infinity loop at start up
Sat Nov 10, 2018 3:56 pm
I'm not sure that's a valid bash command. Also, as /etc/rc.local is run by root you don't need "sudo"
Try splitting those commands over two lines, giving the full path to "python", capturing any output and starting both as background jobs e.g.
/usr/bin/python /home/pi/MFRC522-python/Read.py >/tmp/Read.log 2>&1 &
/usr/bin/python /home/pi/Flask/Webservis.py >/tmp/Webservis.log 2>&1 &
If one, or both, fail to start look in the log file for error messages.
Or create your own systemd service instead (don't ask me how. I'm just saying it before someone else does ;))
Oh, and how are you checking that both process are(not) running? Looking for output? Via somethinglike 'ps aux|grep python'?
Note to self: don't feed the trolls
If I've asked you a question, please answer it. I'm unlikely to be able to help without that information.
klricks
Sat Nov 10, 2018 3:59 pm
The & means start the program in the background...... It does not mean start one and then start another. So your second command is lilely being ignored.
Run them on 2 separate lines:
exit 0
Note that rc.local will probably try to start each program at near the same time. If that matters then start both programs in rc.local using a single bash script.
Unless specified otherwise my response is based on the latest and fully updated Raspbian Stretch w/ Desktop OS.
meminoglu
Sat Nov 10, 2018 5:20 pm
I solved problem with run as a service, maybe this post will help others;
i created two files;
sudo nano /lib/systemd/system/WEB.service
sudo nano /lib/systemd/system/READ.service
i modified both files with nano editor like this;
[Unit]
Description=My Sample Service
After=multi-user.target
[Service]
Type=idle
ExecStart=/usr/bin/python [Place here your file dir]
[Install]
WantedBy=multi-user.target
save your file; after that give permission both files;
sudo chmod 644 /lib/systemd/system/WEB.service
sudo chmod 644 /lib/systemd/system/READ.service
and configure it for both files;
sudo systemctl daemon-reload
sudo systemctl enable WEB.service
source; https://www.dexterindustries.com/howto/ ... t-startup/
Return to “Advanced users”
