nm_rpi
mount f2fs usd HDD with rw permissions
Thu Sep 20, 2018 5:27 am
Finally formatted my external USB HDD to f2fs (to load the blockchain). How do i mount it so that i can read/write to it?
[email protected]:~ $ sudo mount -t f2fs -o rw /dev/sda1 /mnt/usbstorage/
[email protected]:~ $ mkdir /mnt/usbstorage/.bitcoin
mkdir: cannot create directory ‘/mnt/usbstorage/.bitcoin’: Permission denied
thagrol
Re: mount f2fs usd HDD with rw permissions
Thu Sep 20, 2018 11:17 am
The mount will be owned by root so you need to set permissions apropriately after mounting or change your mount options.
Try this:
sudo mount -t f2fs -o rw,uid=pi.gid=pi /dev/sda1 /mnt/usbstorage/
unmount it first if already mounted or add remount to the mount options.
Alternatively, after mounting:
sudo chmod a+rwx /mnt/usbstorage/
This assumes f2fs supports linux file permissionns.
Note to self: don't feed the trolls
If I've asked you a question, please answer it. I'm unlikely to be able to help without that information.
nm_rpi
Thu Sep 20, 2018 4:59 pm
Hello thagrol,
I got some "wrong fs type, bad option" message when i tried to pass -o param. (Again, i am guessing you had a typo when you did rw,uid=pi.gid=pi , and you meant to have a comma. Correct me if i am wrong).
[email protected]:~ $ sudo mount -t f2fs -o rw,uid=pi,gid=p1 /dev/sda1 /mnt/usbstorage/
mount: wrong fs type, bad option, bad superblock on /dev/sda1,
       missing codepage or helper program, or other error
       In some cases useful info is found in syslog - try
       dmesg | tail or so.
However, doing chmod worked.
[email protected]:~ $ sudo chmod a+rwx /mnt/usbstorage/
[email protected]rrypi:~ $
I was hoping to create entry in fstab and it doing an automount but looks like I will need to manually mount (and do a chmod) every-time i startup but thats ok i guess.
thagrol
Thu Sep 20, 2018 6:25 pm
Hello thagrol,
       dmesg | tail or so.
Yeah, that should have been a comma. Sorry
Something like this should work though I'd advise using UUID or PARTUUID instead of /dev/sda1
/dev/sda1	/mnt/usbstorage	f2fs	nofail,rw,uid=pi,gid=pi	0	0
"nofail" is included so that the Pi will boot if the HDD is not connected.
Return to “Advanced users”
