dragondad
look for all in one touch screen solution to connect to Raspberry Pi without need set up by keyboard, mouse, monitor
Fri Aug 17, 2018 4:24 pm
I bought a 3.5 inch touch screen LCD for Raspberry Pi, but I realized that it is not the solution what I need, it still require the complex set up (use external keyboard, mouse, monitor) before you can use it, it is a good solution for LCD display and control panel, but only after all the set up has been done.
My case is, I really look for the all in one touch screen solution, which absolutely no keyboard, mouse or monitor set up required, just hook, and may be multiple interface connected to RPI, then can start to power and run (of course, the RPI image has already been burned into the SD card.
If you have the suggestion, please let me know, thank you.
BeauSlim
Re: look for all in one touch screen solution to connect to Raspberry Pi without need set up by keyboard, mouse, monitor
Sat Aug 18, 2018 10:20 pm
A display that plugs into the HDMI for video and into the USB for touch/mouse input _should_ let you get going out of the box.
Return to “Advanced users”
