szapo
Ethernet between 3B+ and multiple Zero W
Thu Aug 16, 2018 6:17 am
Good morning!
I am thinking of building a 3-touchscreen system that consists of a Pi 3B+ and 2 or more Zero W, all powering a small touchscreen.
My software uses Java and Apache Thrift for RPC, hence I need to have all Zeros communicate with the "Master" 3B+ as fast as possible.
Apache Thrift uses TCP communication.
Now I read about this Ethernet gadget mode, and I am not sure if this is the thing that I need.
What I would like to achieve is to connect the Zeros via USB to the 3B+ and have a new network interface for each connected one on both sides, which allows me to do standard ethernet actions (TCP, UDP) between those devices.
Is that possible? And if so, what speeds are possible?
Re: Ethernet between 3B+ and multiple Zero W
Thu Aug 16, 2018 9:00 am
Good morning!
Do you mean something like this ?
viewtopic.php?f=63&t=130815&p=874890#p874890
adieu
My other Computer is an Asus CS10 ChromeBit
szapo
Thu Aug 16, 2018 11:58 am
Apparently it is that easy.
Thank you for providing the link, this is very helpful and should be a prove that it works, which I will try out of course.
Sometimes you're just googling for the wrong terms ..
drgeoff
Thu Aug 16, 2018 4:41 pm
IP over USB is not ethernet.
szapo
Thu Aug 16, 2018 8:27 pm
Right you are, Harry :)
ejolson
Fri Aug 17, 2018 5:03 pm
A related resource is setting up this super-cheap cluster using 5 Pi Zero computers with root filesystems mounted over the USB Ethernet gadgets.
Return to “Advanced users”
