ethanderson
Shell command on client connect to softAP
Tue Aug 14, 2018 2:31 pm
I'm currently running a client and a server off of my RPIZ w as per this tutorial:
https://blog.thewalr.us/2017/09/26/rasp ... mode-wifi/
Everything is working well but I was curious if there was a way to run a shell command to say, run a python script on client connection to my softAP.
epoch1970
Re: Shell command on client connect to softAP
Fri Aug 17, 2018 2:01 pm
You should be able to use “hostapd_cli -a script.sh” for this. Example.
Return to “Advanced users”
