gulliverrr
Switching 24V - 220V AC with Triac and Opto (Schematic)
Thu Aug 09, 2018 3:34 pm
I am designing an interface for Raspberry to switch AC voltages from 24V AC up to 220V AC.
Simple ON/OFF, nothing fancy.
Current will not exceed 0.5A.
MOC3063 is used to drive a BT134 like below:
https://imgur.com/j2feM8Z
Would that work? I plan on not using any heatsink.
wh7qq
Re: Switching 24V - 220V AC with Triac and Opto (Schematic)
Fri Aug 10, 2018 5:18 am
There are plenty of packaged solid state relays that will do the same job with fewer components. Is there a good reason to re-invent the SSR?
gulliverrr
Mon Aug 13, 2018 9:38 pm
No :)
I was not aware (of small size SSRs). Another friend pointed to the right direction too.
Thank you!
wh7qq
Tue Aug 14, 2018 2:29 am
Not sure what you found but the OPTO22 MP120D4 probably fits your needs and it is about 1"x1.5"x0.5" (rough eyeball measure).
gulliverrr
Tue Aug 14, 2018 4:42 pm
OPTO22 MP120D4 supports up to 2A and this makes a great difference in the price (and size, although it isn't huge either).
If I set the current to as low as 0.5A I get results for 3-4 USD.
Will keep OPTO22 MP120D4 in mind for future projects. Thanks!
Return to “Advanced users”
