I am using this library: https://github.com/yhirose/cpp-httplib
This is html file
<!DOCTYPE html>
<html lang="en">
<head>
<script type="text/javascript" src="jquery.min.js"></script>
<script type="text/javascript" src="vue.js"></script>
<meta charset="UTF-8">
<meta name="viewport" content="width=device-width, initial-scale=1.0">
<meta http-equiv="X-UA-Compatible" content="ie=edge">
<title>PassGate Configuration</title>
</head>
<body>
<div class="container" id="pass-app">
<form class="form" id="myform" method="post">
<h4 class="text-center">Configuration</h4>
<h3>Ethernet Configuration</h3>
<fieldset>
<span for="dhcp">DHCP</span>
<input type="checkbox" name="switch" id="switch" v-model="json.dns"/>
</fieldset>
<fieldset>
<span>IP</span>
<input id="ip" type="text" v-model="json.ip" required>
</fieldset>
<fieldset>
<span>DNS</span>
<input id="dns" type="text" v-model="json.dns">
</fieldset>
<fieldset>
<span>GateWay</span>
<input id="gate" type="text" v-model="json.gate">
</fieldset>
<fieldset>
<span>Subnet</span>
<input id="sub" type="text" v-model="json.sub">
</fieldset>
<h3>Server </h3>
<fieldset>
<span>Server</span>
<input id="sv" type="text" v-model="json.sv">
</fieldset>
<fieldset>
<span>Port</span>
<input id="port" type="text" v-model="json.port">
</fieldset>
<fieldset>
<span>Path</span>
<input id="svurl" type="text" v-model="json.svurl">
</fieldset>
<h3>Update Server</h3>
<fieldset>
<span>Port</span>
<input id="svUp" type="text" v-model="json.svUp">
</fieldset>
<fieldset>
<span>Path</span>
<input id="scurlUp" type="text" v-model="json.svurlUp">
</fieldset>
<h3>SIM</h3>
<fieldset>
<span>SIM</span>
<input id="sim" type="text" v-model="json.sim">
</fieldset>
<fieldset>
<button name="submit" onclick="submitform()" type="submit" class="form-submit" data-submit="...Sending">Save</button>
</fieldset>
</form>
<div class="text-center m-t-10">
<a class="reset-button" href="/reset"> Reset</a>
</div>
</div>
<script type="text/javascript">
var jsonURL = '/saved';
new Vue({
el: '#pass-app',
data: {
json: { }
created: function () {
fetch(jsonURL)
.then(r => r.json())
.then(json => {
this.json=json;
function submitform() {
console.log("click");
//var url = '/update?UpdateData';
var url = '/update';
$('.form').attr('action', url);
var data = JSON.stringify({
"ip": $('#ip').val(),
"dns": $('#dns').val(),
"gate": $('#gate').val(),
"sub": $('#sub').val(),
"sv": $('#sv').val(),
"port": $('#port').val(),
"svurl": $('#svurl').val(),
"svUp": $('#svUp').val(),
"portUp": $('#portUp').val(),
"svurlUp": $('#svurlUp').val(),
"sim": $('#sim').val()
console.log(data);
$("#myform").submit();
</script>
<style type="text/css">
@import url(https://fonts.googleapis.com/css?family=Roboto:400,300,600,400italic); * { margin: 0; padding: 0; box-sizing: border-box; -webkit-box-sizing: border-box; -moz-box-sizing: border-box; -webkit-font-smoothing: antialiased; -moz-font-smoothing: antialiased; -o-font-smoothing: antialiased; font-smoothing: antialiased; text-rendering: optimizeLegibility; }
.text-center{text-align: center;}
body { font-family: "Roboto", Helvetica, Arial, sans-serif; font-weight: 100; font-size: 12px; line-height: 30px; color: #777; background: #6a3ca8; }
.container { max-width: 400px; width: 100%; margin: 0 auto; position: relative; }
.m-t-10{margin-top: 10px;}
.form input[type="text"], .form input[type="email"], .form input[type="tel"], .form input[type="url"], .form textarea, .form button[type="submit"] { font: 400 12px/16px "Roboto", Helvetica, Arial, sans-serif; }
.form { background: #F9F9F9; padding: 25px; margin: 10px 0; box-shadow: 0 0 20px 0 rgba(0, 0, 0, 0.2), 0 5px 5px 0 rgba(0, 0, 0, 0.24); }
.notification-box{ background: #F9F9F9; padding: 25px; margin: 150px 0; box-shadow: 0 0 20px 0 rgba(0, 0, 0, 0.2), 0 5px 5px 0 rgba(0, 0, 0, 0.24); }
.notification-box p{font-weight: 600; line-height: 18px;}
.form h3 { display: inline-block; border-bottom: 1px solid #000; font-size: 20px; font-weight: 300; margin-bottom: 10px; }
.form h4 { margin: 5px 0 15px; display: block; font-size: 16px; font-weight: 400; }
fieldset { border: medium none !important; margin: 0 0 10px; min-width: 100%; padding: 0; width: 100%; }
.form span {float:left; width: 25%; line-height: 40px;}
.form input[type="text"], .form input[type="email"], .form input[type="tel"], .form input[type="url"], .form textarea { width: 75%; border: 1px solid #ccc; background: #FFF; margin: 0 0 5px; padding: 10px; }
.form input[type="text"]:hover, .form input[type="email"]:hover, .form input[type="tel"]:hover, .form input[type="url"]:hover, .form textarea:hover { -webkit-transition: border-color 0.3s ease-in-out; -moz-transition: border-color 0.3s ease-in-out; transition: border-color 0.3s ease-in-out; border: 1px solid #aaa; }
.form textarea { height: 100px; max-width: 100%; resize: none; }
.form button[type="submit"] { cursor: pointer; width: 100%; border: none; background: #6a3ca8; color: #FFF; margin: 0 0 5px; padding: 10px; font-size: 15px; }
.form button[type="submit"]:hover { background: #3d1670; -webkit-transition: background 0.3s ease-in-out; -moz-transition: background 0.3s ease-in-out; transition: background-color 0.3s ease-in-out; }
.form button[type="submit"]:active { box-shadow: inset 0 1px 3px rgba(0, 0, 0, 0.5); }
.form input:focus, .form textarea:focus { outline: 0; border: 1px solid #aaa; }
::-webkit-input-placeholder { color: #888; }
:-moz-placeholder { color: #888; }
::-moz-placeholder { color: #888; }
:-ms-input-placeholder { color: #888; }
/*.jsless-switchery input { display: none; } .jsless-switchery label { background-color: #fff; border: 1px solid #dfdfdf; border-radius: 20px; cursor: pointer; display: inline-block; height: 30px; position: relative; vertical-align: middle; width: 50px; user-select: none; box-sizing: content-box; background-clip: content-box; border-color: #dfdfdf; box-shadow: #dfdfdf 0px 0px 0px 0px inset; transition: border 0.4s, box-shadow 0.4s; background-color: #ffffff; } .jsless-switchery label:after { content: ""; background: #fff; border-radius: 100%; box-shadow: 0 1px 3px rgba(0, 0, 0, 0.4); height: 30px; position: absolute; top: 0; width: 30px; left: 0px; transition: background-color 0.4s, left 0.2s; } .jsless-switchery input:checked ~ label { border-color: #6a3ca8; box-shadow: #6a3ca8 0px 0px 0px 16px inset; transition: border 0.4s, box-shadow 0.4s, background-color 1.2s; background-color: #6a3ca8; } .jsless-switchery input:checked ~ label:after { left: 20px; transition: background-color 0.4s, left 0.2s; background-color: #ffffff; } .jsless-switchery { width: 60px; float: left; }*/
.reset-button{padding: 10px; text-align: center; color: #6a3ca8; background: #fff; box-shadow: 0 0 20px 0 rgba(0, 0, 0, 0.2), 0 5px 5px 0 rgba(0, 0, 0, 0.24); font-size: 22px; text-decoration: none; margin-bottom:15px; display: inline-block;} .reset-button:hover{background: #f5f5f5}
</style>
</body>
</html>
The line where I print out "BEFORE BODY" looks empty. So I never get the data from form. I am trying to go the adress where I wrote inside of svr.listen() function.
void *threadHttp(void *threadid)
while(isLoggerBusy){
sleepcp(13);
putLog("HTTPService",2,"Service Started");
cout << 1 << endl;
using namespace httplib;
Server svr;
svr.Get("/", [](const Request& req, Response& res) {
res.set_content(readFile("index.html"), "text/html");
sleepcp(13);
putLog("HTTPService",2,"Incoming Request to server/");
svr.Get("/jquery.min.js", [](const Request& req, Response& res) {
res.set_content(readFile("jquery.min.js"), "text/javascript");
svr.Get("/vue.js", [](const Request& req, Response& res) {
res.set_content(readFile("vue.js"), "text/javascript");
svr.Post("/update", [&](const auto& req, auto& res) {
auto size = req.files.size();
auto ret = req.has_file("update");
const auto& file = req.get_file_value("update");
// file.filename;
// file.content_type;
/*cout << "req" << endl;
cout << req << endl;*/
cout << "BEFORE BODY" << endl;
cout << ret << endl;
auto body = req.body.substr(file.offset, file.length);
cout << "INSIDE OF THE BODY" << endl;
cout << body << endl;
delay(1000);
putConfigs(body);
res.set_content("ok", "text/plain");
svr.Get("/saved", [](const auto& req, auto& res) {
res.set_content(readFile("configs.txt"), "text/plain");
cout << "2" << endl;
/*svr.Post("update/", [](const Request& req, Response& res) {
auto numbers1 = req.matches[1];
cout << "incoming request" << endl;
cout << numbers1 << endl;
res.set_content(req.body(), "text/plain");
svr.listen("192.168.0.150", 8080);
sleepcp(13);
putLog("HTTPService",0,"Service Exit...");
pthread_exit(NULL);
void putConfigs(string data){
ofstream myfile ("configs.txt");
if (myfile.is_open())
myfile << data;
myfile.close();
else cout << "Unable to open file";
string readFile (char* fileLocation) {
string fileAll;
string line;
ifstream myfile (fileLocation);
while ( getline (myfile,line) )
fileAll += line;
myfile.close();
return fileAll;
