klintkrossa
Turn RPi into a python3 kiosk when usb bar-code reader is plugged in
Tue Jul 31, 2018 7:57 pm
Hello
How to turn RPi into a python3 kiosk when usb bar-code reader is plugged in?
I have the bar code reader program that I would like to test.
Where I have the problem is that if the program is not running if the bar code reader reads a bar code it put it where ever the text can go.
A web page would be a big disaster.
This is not like any other bulletin boards that I have been on. Been flamed on other BB's so bad I was afraid to ask.
All my Raspberry Pi's are like the Hessian artilleryman of Sleepy Hollow.
topguy
Re: Turn RPi into a python3 kiosk when usb bar-code reader is plugged in
Wed Aug 01, 2018 2:28 pm
In what kind of environment does your Pi live if you cant control if someone plugs in the reader and starts scanning stuff ?
Is there a problem with running the program without the barcode reader plugged in ?
How is your program reading the scanned codes from the scanner ? Is it a GUI program that needs to be in "focus"/"on top" for it to work ? Or is it reading directly from the "evdev" device.
I assume that the barcodescanner works as a Keyboard ( HID-device ), have you checked if the scanner also can work as a serialport device ?
If the pi could see the scanner as a serialport then it will not interfere with programs like a browser.
You could also check if you can prevent X-Windows for using the scanner as a Keyboard.
klintkrossa
Sat Aug 04, 2018 4:20 am
Thanks for the reply
I am looking to make the scanner focus on an input for a python3 script to log the upc. That way I can log the food in and use. I was hopping that when i plug in the upc reader It would bring up the python3 script and run the logging. there is a upc look up part to the script to.
DarkElvenAngel
Mon Aug 20, 2018 7:08 pm
You have a few options for this, I have a setup for starting a hotspot when a Wi-Fi device is installed but changing it for an HID device is simple enough.
You need to write a udev rule to detect your scanner and create a symlink say barcodescanner then you can write a service and a path file for systemd to watch for that device to be add. The service file can start your script and off you go.
Return to “Advanced users”
