B.Goode wrote:
can Raspberry look into a git repository or some sort of server and if there is change in the version download and run new software? [ ... ]
Can someone suggest me something?
Resin.IO ?
https://resin.io
I think resin.io is not free service :/
topguy wrote:
Git is not a bad idea..
You need to install a script on the pi which "cron" ( or similar service ) will start at regular intervals.
The script does the follwing:
- Do a "git pull",
- look at resultcode or output to see if something new is sucessfully downloaded.
- delete old file, copy in new file.
- kill and restart your program.
A smoother (and less hacky) way is to create a .deb package of your application. And install your application as a systemd service.
- You can add/remove files when needed because all is in the deb-package and old files are automatically removed. ( dont need to manually delete/copy files )
- You can add scripts that automatically restarts the service after installation or the new version. ( dont need to manually restart program )
- You can even have the ( now quite short) upgrade script as part of the package.
-- But you have to learn a thing or two about deb-packages and systemd.
I am totally stranger to the second way. First one looks easier to me. But first I need to do some research. Do you know any good tutorial or documentation about second suggestion?
Also I have a question about second one. Do you have any idea how am i going to change files from a far network? I think again I would need a script which will check for differences between files.
Edit: I found something called capistrano. Would it be my solution?
