itdontgo
Turn off command line storage
Thu Jul 19, 2018 11:24 am
I have an application where a micro-controller enters data into the Raspberry Pi via the commend line (using the UART). It types something like:
echo "10.1" > file.txt
It does this over and over every second.
I store the 'file.txt' on the RAM drive as I don't want repeated writes to the SD card - this has to last a long time.
When you press the up arrow you get the previous commands entered. This must be stored somewhere on the flash drive. I either want to store this in RAM or disable it so I don't keep writing to the SD card every second. Is this possible?
timg236
Re: Turn off command line storage
Thu Jul 19, 2018 11:38 am
You can disable the bash history with this command
set +o history
See https://linuxconfig.org/how-to-disable- ... y-on-linux
DirkS
Thu Jul 19, 2018 11:43 am
By default commands that start with a space are not put in the history.
See e.g. https://stackoverflow.com/questions/647 ... sh-history
BTW: if a command is a duplicate of the previous one it should not be added to the history either.
itdontgo
Thu Jul 19, 2018 12:28 pm
That's great thanks!
PeterO
Thu Jul 19, 2018 2:08 pm
+1 Useful tip !
PeterO
Return to “Advanced users”
