Bakerman3
Power Rpi 3 B+ from led strip PSU
Wed Jul 18, 2018 2:18 pm
Hello guys!
So I have the following 5V 30amp led strip psu which I am currently using to power several other brand microcontrollers, however these boards use a simply dc Jack for power, I'm wondering if I cut the USB end off a regular USB wire, can I simply hook power and ground up to the psu in other to supply power to my Rpi via the micro USB end?
Meaning I would be leaving the 2 data lines of the USB dangling and only running power and ground to the Rpi. Or would this not work?
MarkTF
Re: Power Rpi 3 B+ from led strip PSU
Wed Jul 18, 2018 3:48 pm
Looking at the Pi3 and Pi3+ schematics, the specified input voltage upper limit for the regulator is about 5.5 V, so putting 12 V in would almost certainly fry the board.
You can get efficient 12 to 5 volt regulators from a number of sources. e.g. https://www.pololu.com/product/2850.
Paul Webster
Contact: Twitter
Wed Jul 18, 2018 3:51 pm
OP says it is 5V not 12V
Paul Hutch
Wed Jul 18, 2018 4:13 pm
That should work fine as long as you use a large gauge power wire and/or keep it very short.
That appears to be a Mean Well power supply, one of my favorites, which will only put out 5.0V. With the large current draw and voltage level sensitivity of a RasPi 3B+ having a 5.2V output power supply is better for longer, or thinner gauge, wires.
drgeoff
Wed Jul 18, 2018 4:24 pm
The PSU pictured has adjustable voltage output. The small pot at the right hand end of the terminal block is so labelled.
Paul Hutch
Wed Jul 18, 2018 4:31 pm
Excellent, I didn't spot the adjustment pot in the picture and the last 5V Mean Well I bought was not adjustable.
Bakerman3
Wed Jul 18, 2018 7:30 pm
Thanks for th guidance guys, will post my results here once I get my hands on some decent micro USB wires!
Return to “Advanced users”
