Aydan
Using framebuffer as overlay for the camera preview
Fri Jun 22, 2018 11:06 am
Hello Everybody,
is there any way to put the camera preview layer behind the framebuffer and make the framebuffer partially transparent (e.g. by color keying)?
What I want to do is to show the camera preview and have UI components (Buttons/Labels) ontop of it.
I do not want or need to have those UI elements show up in camera captures.
Regards
Aydan
topguy
Re: Using framebuffer as overlay for the camera preview
Fri Jun 22, 2018 1:32 pm
In which (programming) language do you intend to implement this in ?
Python picamera module has some functionality.
https://picamera.readthedocs.io/en/rele ... he-preview
There have been several threads on the subject before with valuable information, but not all of them are easy to find.
viewtopic.php?p=702598
The important part is to know that the GPU in the Pi support different "layers" and you can get software that uses the dispmanx API to show on different layers. ( ref: viewtopic.php?p=94738 )
Aydan
Wed Jul 04, 2018 11:21 am
The goal would be to use picamera in combination with a canvas widget inside a tkinter application to show the camera preview.
I can kind of do this right now, with the drawback that the preview port will always be ontop of the framebuffer and I'd have to make it transparent or disable it completely when the app showing the preview loses focus, so other apps can be used.
The ideal situation would be to e.g. set a specific background color for the canvas widget, and the camera previev would only be visible where the framebuffer has this specific color.
If I remember correctly this is what DirectVideo on Windows does when hardware video decoding is used, because I remember wondering why I could see video fragments through the text of filenames in the file explorer, when the explorer window was partially obscuring a video playback.
I know that picamera supports overlays, but they have some limits e.g. having to be the same size as the preview port, and they don't easily lend themselves for displaying UI elements on them.
Regards
Aydan
6by9
Wed Jul 04, 2018 12:34 pm
So your main issue is adding alpha somewhere to the frame buffer, not really the preview window at all.
The default frame buffer is an XRGB8888 layer, but there is a mailbox call that allows you to set it alpha observed. https://github.com/raspberrypi/linux/bl ... are.h#L126
The other issue may be that the frame buffer is at layer -127, which is the lowest layer it can be. There appears to be a mailbox calls defined for setting the layer
      GET_LAYER                  = 0x0004000c,
      TST_LAYER                  = 0x0004400c,
      SET_LAYER                  = 0x0004800c,
that may allow you to amend the layer as required.
Aydan wrote:I know that picamera supports overlays, but they have some limits e.g. having to be the same size as the preview port, and they don't easily lend themselves for displaying UI elements on them.
I'm not sure where you get the size limitation from. AFAIK they are totally independent of the camera itself, and are just extra instances of the video_render component that you can throw an arbitrary bitmap at. https://picamera.readthedocs.io/en/late ... he-preview
6by9
Wed Jul 04, 2018 12:36 pm
And chroma keying (using a specific colour to dictate alpha) is often very inefficient as a way to determine that alpha. Always go for a dedicated alpha channel if you can (in this case I think you're forced to).
6by9
Wed Jul 04, 2018 12:45 pm
To adjust the layer to being -5:
sudo /opt/vc/bin/vcmailbox 0x0004800c 4 4 -5
Actually it's a config.txt setting to enable alpha, from which you can then set it again via the mailbox.
framebuffer_ignore_alpha=0
Aydan
Wed Jul 04, 2018 1:30 pm
@6by9, thanks for the tips.
Now the problem will be to convince X11 to write the alpha value of an application widget to the framebuffer, and not showing me the desktop/app behind the window. :lol:
This would not be a problem with colour keying.
I may just have to run my ap in direct framebuffer mode without X :(
Regards
Aydan
Aydan
Thu Oct 04, 2018 11:46 am
I finally had some time to implement the Tk widget which controls the size and position of the preview port, but I have yet to find a way to get an alpha value from an application down to the framebuffer. There are too many layers between the framebuffer and my application that "eat" the alpha value.
I did find something in the V4L2 documentation for video overlay. They offer chroma keying as one way to control video overlays.
Chroma keying is still my preferred solution, because it is so easy for the application developer to control.
Regards
Aydan
Aydan
Sun Oct 07, 2018 11:34 am
Return to “Camera board”
