How to Install Autofs for NFS connections
Posted: Wed Jun 06, 2018 3:10 am
by Daddyfix
I spent a few days figuring out how to properly install autofs, and automount system on Raspberry Pi 3 Jessie. Hope this helps someone else
Install
First thing to do is install the automount package
sudo apt-get update
sudo apt-get upgrade
sudo apt-get install autofs
Check Files in Package
When I installed autofs on RPi 3 Jessie only two files were installed. If you notice that automount was not installed then you have to get the .deb files from debian and install manually
$ dpkg-query -L autofs
/etc
/etc/init.d
/etc/init.d/autofs
Notice automount was not installed? now we are going to install it manually
Get Raspian Version
$ cat /etc/os-release
PRETTY_NAME="Raspbian GNU/Linux 8 (jessie)"
NAME="Raspbian GNU/Linux"
VERSION_ID="8"
VERSION="8 (jessie)"
ID=raspbian
ID_LIKE=debian
Get Architecture
dpkg --print-architecture
armhf
Download correct version & architecture
Download .deb and install based on your Raspian above
https://packages.debian.org/search?keywords=autofs
$ cd /tmp
$ wget "wget http://ftp.ca.debian.org/debian/pool/main/a/autofs/autofs_5.0.8-2+deb8u1_armhf.deb"
Remove Old autofs and install autofs_5.0.8-2+deb8u1_armhf.deb
$ sudo apt-get update
$ sudo apt-get remove autofs --purge
$ sudo dpkg -i autofs_5.0.8-2+deb8u1_armhf.deb
Check for automount files
/etc
/etc/init.d
/etc/init.d/autofs
/usr
/usr/lib
/usr/lib/arm-linux-gnueabihf
/usr/lib/arm-linux-gnueabihf/autofs
/usr/sbin
/usr/sbin/automount
/usr/lib/arm-linux-gnueabihf/autofs/mount_nfs4.so
Notice automount was installed with autofs package
Configure
Make mount point directories /mnt/nfs/
$ mkdir -p /mnt/nfs/mycloud
$ mkdir -p /mnt/nfs/mobilesvr
Edit /etc/auto.master and add a autofs file
/mnt/nfs/mycloud        /etc/mycloud.nfs    uid=501,gid=1000 --timeout=6000 --ghost
/mnt/nfs/mobilesvr      /etc/mobilesvr.nfs  uid=0,gid=0      --timeout=6000 --ghost
uid and gid are user and group id's on the nfs servers.
Edit /etc/mycloud.nfs and add mount points
The following is a NFS filetype connection.
storage     -fstype=nfs,rw,hard,nolock,noauto,x-systemd.automount   192.168.1.100:/nfs/Storage
Restart Service
$ systemctl restart autofs.service
Test
$ l /mnt/nfs/mycloud
file1.txt
If the folder is not empty then you are succesfull.
Check Mounts
$ mount | grep mycloud
/etc/mycloud.nfs on /mnt/nfs/mycloud type autofs (rw,relatime,fd=-1,pgrp=816,timeout=6000,minproto=5,maxproto=5,indirect)
/etc/mycloud.nfs on /mnt/nfs/mycloud type autofs (rw,relatime,fd=7,pgrp=13541,timeout=6000,minproto=5,maxproto=5,indirect)
Re: How to Install Autofs for NFS connections
Posted: Wed Jun 06, 2018 9:12 am
by epoch1970
Or simply do "apt-get install autofs5".
Automount is a bit of an admin thing, AFAIK it never was installed by default on Debian, and Raspbian follows suit.
Also, systemd now (from Jessie? in Stretch for sure) packs an automount service of its own. For simple jobs (there is nothing like maps, indirect or executable mounts in systemd's automount) you can do without installing autofs5.
Posted: Wed Jun 06, 2018 12:29 pm
by Daddyfix
@epoch1970
Geeesh did I ever waste a couple days! :(
Anyhow, thanks for the info on autofs5, and automount in systemd.
I guess I should asked someone here instead of going crazy! :D
Posted: Wed Jun 06, 2018 6:41 pm
by Daddyfix
Posted: Wed Feb 26, 2020 12:30 am
by mingenlee
Is this method still work on Buster? I tried on Buster but it doesn't work anymore.
Posted: Wed Feb 26, 2020 1:18 pm
by Daddyfix
On Buster I use systemd automount NFS
Installation
sudo apt-get install rpcbind nfs-common
Important
Automount units must be named after the automount directories they control.
Example: the automount point /home/lennart must be configured in a unit file home-lennart.mount.
On My RPi
mkdir /nfs/nas
Use the following to find the NFS mounts from you NFS Server IP
$ showmount -e 192.168.1.?
Export list for 192.168.1.?:
/nfs/RemoteNFSDirName 192.168.1.0/24
Setup auto mount Systemd file
/etc/systemd/system/nfs-nas-DIRNAME.mount
[Unit]
Description=NFS Directory
[Mount]
What=192.168.1.?:/nfs/RemoteNFSDirName
Where=/nfs/nas/DIRNAME
Type=nfs
Options=rw,hard,intr,x-systemd.automount
[Install]
WantedBy=multi-user.target
Enable in Systemd
$ systemctl enable nfs-nas-DIRNAME.mount
$ systemctl daemon-reload
$ systemctl start nfs-nas-DIRNAME.mount
$ systemctl status nfs-nas-DIRNAME.mount
Hope this helps you. It took many attempts to make it work for me. :)
Posted: Wed Feb 26, 2020 2:26 pm
by sora03
You can also use /etc/fstab to mount NFS directories. (after you've installed nfs-common)
172.16.1.1:/home/pi/Public  /media/user/Public  nfs noatime,nodiratime,rw,nocto,noacl 0 0
To mount manually:
$ sudo mount -a
To setup Pi as the NFS server, install nfs-kernel-server
In your NFS server (Pi) to add directory, just edit /etc/exports:
/home/pi/Public       172.16.1.0/24(ro,sync,no_subtree_check)
Posted: Thu Feb 27, 2020 7:39 pm
by mingenlee
I found out why it doesn't work for my Buster because the file /etc/autofs.pi redirected by /etc/auto.master has executable bit turn on. Automount thinks it's a shell script file instead of a configured file. Once I use command sudo chmod u-x /etc/autofs.pi then everything works fine. I found out this information from a posted from 2005 which means its a known feature. https://lists.fedoraproject.org/piperma ... 28314.html
Posted: Thu Feb 27, 2020 11:55 pm
by Daddyfix
I'm a little confused...
Is the /etc/autofs.pi file a custom script that you wrote? I don't use auto.master cause it's the old way and didn't work very well for me if the remote NFS server was off or not running.
I found automount with systemd worked best.
I'm really curious about what is in your autofs.pi. could you post it?
