dennisdunbar
How to expand Virtual Memory on RPi B3 +?
Mon Apr 23, 2018 11:59 am
I just set up for first RPi B3+ using Stretch.
I am seeing virtual memory at 203MB.
I would like it to be 1024 MB.
I edited the file at /etc/init.d/dphys-swapfile
CONF_SWAPSIZE=1024
I reboot and I still get 203.
If I stop and start using
/etc/init.d/dphys-swapfile stop
and
/etc/init.d/dphys-swapfile start
It get it to 1203 MB until the next restart.
How to make the expanded size stick?
Many many many RPi, RPi B, RPi 3, RPi B+, RPi 3 B+ and one Zero running 20-30 websites, Word Press, FreePBX, PiAware, PrivateEyePi.
Ernst
Re: How to expand Virtual Memory on RPi B3 +?
Mon Apr 23, 2018 3:24 pm
I normally edit /etc/dphys-swapfile and do a reboot.
# /etc/dphys-swapfile - user settings for dphys-swapfile package
# author Neil Franklin, last modification 2010.05.05
# copyright ETH Zuerich Physics Departement
#   use under either modified/non-advertising BSD or GPL license
# this file is sourced with . so full normal sh syntax applies
# the default settings are added as commented out CONF_*=* lines
# where we want the swapfile to be, this is the default
#CONF_SWAPFILE=/var/swap
# set size to absolute value, leaving empty (default) then uses computed value
#   you most likely don't want this, unless you have an special disk situation
CONF_SWAPSIZE=200
# set size to computed value, this times RAM size, dynamically adapts,
#   guarantees that there is enough swap without wasting disk space on excess
#CONF_SWAPFACTOR=2
# restrict size (computed and absolute!) to maximally this limit
#   can be set to empty for no limit, but beware of filled partitions!
#   this is/was a (outdated?) 32bit kernel limit (in MBytes), do not overrun it
#   but is also sensible on 64bit to prevent filling /var or even / partition
#CONF_MAXSWAP=2048
n67
Mon Apr 23, 2018 3:44 pm
Yes. It seems OP just edited the wrong file.
The right file to edit is /etc/dphys-swapfile.
But this leads to a question: Now that we live in the world of systemd, why are there any files at all in /etc/init.d? Is that just a relic of the old init system? Are the files just there to trap the unwary?
"L'enfer, c'est les autres"
Epmu Sn!
gkaiseril
Mon Apr 23, 2018 6:41 pm
The Raspbian OS is backward compatible to the R Pi 1A, so any new OS must retain compatibility with that model. So in this case it could be wise to update both places if the OP is still using the R Pi 1A.
n67
Mon Apr 23, 2018 6:48 pm
The 1A doesn't use systemd?
Epmu Sn!
mfa298
Mon Apr 23, 2018 6:59 pm
systemd is an OS update (moving away from the old sysvinit) rather than a hardware change so I'm not sure that comment makes sense. With stretch all models of Pi will use systemd by default. Software won't always be backwards compatible (and shouldn't be otherwise you end up with a mess like WinME).
I think not all things have migrated from sysvinit (/etc/init.d) to systemd so systemd will pull in some stuff from /etc/init
gkaiseril
Mon Apr 23, 2018 7:32 pm
That is up to the RPF to make that decision. Their decision is right now to keep that compatability since one of their goals is to provide an affordible computer to teach stidents worldwide including third world countries where even a $35.00 is an expensive purchase for many.
Mon Apr 23, 2018 7:44 pm
It is nothing to do with the RPF. It is a decision by Debian on maintaining compatibility with old sysvinit based programs.
The hardware has nothing to do with it. It's not even just a Pi issue.
MaxK1
Tue Apr 24, 2018 10:38 am
Just a comment: If you NEED that much swap space, you are probably in very deep weeds. You are likely in deep weeds if you even approach 203Mb... Are you sure you haven't allocated too much memory for the GPU?
You are in a maze of twisty little passages, all alike.
When General Failure and Major Disaster get together, Private Parts usually suffers.
dennisdunbar
Tue Apr 24, 2018 11:14 am
Edited /etc/dphys-swapfile., NO GO.
Tue Apr 24, 2018 11:17 am
After you edit the file you need to run the sudo dphys-swapfile program to implement your changes.
Note:Having anything remotely humorous in your signature is completely banned on this forum.
dennisdunbar
Tue Apr 24, 2018 11:29 am
Not in weeds, GPU space fine, WHY NOT, THE SPACE IS THERE!
Tue Apr 24, 2018 12:09 pm
If you are needing to use virtual memory (swap space) on a Pi (or almost any other server really), you need to reconsider things. Are you using the right hardware? Is your application being too memory hungry?
Using virtual memory on a Pi is even worse than using it on a normal server with spinning rust storage. It will be incredibly slow and if you are using it on an SD card it can wear out the card very quickly.
ejolson
Wed Apr 25, 2018 5:37 am
I think you need more than 200MB swap just to compile a new version of gcc.
Swap rate and swap size, while related, are not the same. I remember Linux swap working much better on the 1.2.x and 2.0.x series kernels than it does these days. However, that memory may not be accurate. It is interesting the way Linux user land reinvents the wheel with systemd and others and then keeps using the old wheels as well. If I did the same with my car it would be impossible to drive and likely destroy the road if I tried.
jahboater
Wed Apr 25, 2018 5:56 am
The main point here is that the swap is needed for a few minutes only during the 4.5 hour build, but it enables the build to complete.
Reducing the memory usage (with "make" say instead of "make -j4") would slow the build down a lot by only using one core. ( "make -j4" runs four compilations at the same time utilizing all four cores on the Pi).
So using swap reduces the build time by roughly a factor of four - cant be bad!
My build script just has this in it:-
#  For the Pi or any computer with less than 2GB of memory
if [ -f /etc/dphys-swapfile ]; then
  sudo sed -i 's/^CONF_SWAPSIZE=[0-9]*$/CONF_SWAPSIZE=1024/' /etc/dphys-swapfile
  sudo /etc/init.d/dphys-swapfile stop
  sudo /etc/init.d/dphys-swapfile start
fi
For interest, the other (really slow) way of adding swap is:-
sudo dd if=/dev/zero of=/swapfile1GB bs=1G count=1
sudo chmod 0600 /swapfile1GB
sudo mkswap /swapfile1GB
sudo swapon /swapfile1GB
dennisdunbar
Wed Apr 25, 2018 7:52 am
Tried that, here is what I got:
[email protected]:~# dphys-swapfile
Usage: /sbin/dphys-swapfile {setup|swapon|swapoff|uninstall}
[email protected]:~# dphys-swapfile setup
want /var/swap=1024MByte, checking existing: keeping it
[email protected]:~# dphys-swapfile swapon
After reboot, no go, still 203.
jahboater
Wed Apr 25, 2018 8:07 am
Please read my previous post which has a script entry that does the edit and restarts swap.
You need:-
dennisdunbar
Wed Apr 25, 2018 11:32 am
You need:-
Did that NO GO.
jahboater
Wed Apr 25, 2018 11:48 am
Well four suggestions,
1) have you got enough disk space?
2) have you correctly updated /etc/dphys-swapfile ?
Perhaps post it here.
3) check to see if /var/swap is the correct size
Use: ls -lh /var/swap
4) use "free -h" to show your swap
It works fine for me everytime on any Pi model.
The change is immediate, you do not have to reboot.
dennisdunbar
Wed Apr 25, 2018 11:57 am
Well two suggestions,
It works fine for me on any Pi model.
Yes it always worked, I have 5 or 6 other here running no problem.
Like I said this is my first Stretch and my first Pi B3+
I have the memory,
I'll post the info in a bit
jahboater
Wed Apr 25, 2018 11:58 am
It works on stretch too!
Perhaps your sd card is faulty or old
PeterO
Wed Apr 25, 2018 12:32 pm
You need:-
Did that NO GO.
Did you do all of if though ...
fi
What is in the file "/etc/dphys-swapfile" on your machine ?
PeterO
Interests: C,Python,PIC,Electronics,Ham Radio (G0DZB),Aeromodelling,1960s British Computers.
dennisdunbar
Thu Apr 26, 2018 1:40 am
PeterO
[/quote]
CONF_SWAPSIZE=1024
#CONF_SWAPFACTOR=2
#CONF_MAXSWAP=2048
dennisdunbar
Thu Apr 26, 2018 1:43 am
Has for me previously,
ls -lh /var/swap
-rw------- 1 root root 1.0G Apr 22 19:06 /var/swap
dennisdunbar
Thu Apr 26, 2018 1:51 am
ls -lh /var/swap
free -h
total used free shared buff/cache available
Mem: 748M 163M 174M 17M 410M 512M
Swap: 203M 0B 203M
Return to “Advanced users”
