manawyrm
[Pi 3B+] WiFi 433Mbit/s - VHT80 / 802.11ac
Mon Mar 19, 2018 7:26 am
I'm currently testing the wifi capability of the new Pi 3B+ and it's CYW43455.
My access point is a Ubiquiti AC AP Lite, that can do 2x2 MIMO at VHT80, already properly tested with other 11ac capable devices, like my phone or laptop. The AP can do 700 MBit/s+.
This is the situation on the Pi:
It only syncs to about 200 MBit/s, which would be exactly fitting for it only using a 40 MHz channel, instead of an 80MHz one.
(I strongly hope that the TX power is just a wrong report, or else I'm properly breaking german law ;) )
The regulatory domain is properly set to germany, which allows 80MHz channels:
The chip (http://www.cypress.com/file/358916/download ) also supports 80MHz wide channels.
What is limiting the WiFi bandwidth here?
EDIT: Some more information for reference:
brcmfmac: brcmf_fw_map_chip_to_name: using brcm/brcmfmac43455-sdio.bin for chip 0x004345(17221) rev 0x000006
brcmfmac: brcmf_c_preinit_dcmds: Firmware version = wl0: Feb 27 2018 03:15:32 version 7.45.154 (r684107 CY) FWID 01-4fbe0b04
brcmfmac: brcmf_c_preinit_dcmds: CLM version = API: 12.2 Data: 9.10.105 Compiler: 1.29.4 ClmImport: 1.36.3 Creation: 2018-03-09 18:56:28
[email protected]:~# uname -r
4.14.27-v7+
Best wishes,
Tobias
Seketh
Re: [Pi 3B+] WiFi 433Mbit/s - VHT80 / 802.11ac
Mon Mar 11, 2019 1:22 pm
I'm reviving this thread as I have the exact same issue, my region is set to PT, and my Raspberry 3 A+ is only using 40MHz, syncs to 200mb/s.
If I set the region to US, either using iw reg set US or modifying wpa_supplicant.conf, the raspberry correctly uses 80MHz, however, wifi seems to restart every 10 seconds or so. Maybe I'm just looking in the wrong place, but I can't understand why it restarts.
Is there any solution for this? Double the bandwith would be very welcome!
Mushoz
Thu Mar 28, 2019 9:54 am
I have the exact same issue with the NL region set.
Return to “Advanced users”
