itsacoolaccount
SSH IP Filter
Sun Mar 18, 2018 8:09 pm
So I've got a server up and running and all that's left on my list is only allowing certain IP's (a local and a remote IP), but I can't find the file or setting to do it.
HELP ME PLEASE
sudo apt-get install coffee
fbe
Re: SSH IP Filter
Sun Mar 18, 2018 11:23 pm
https://www.raspberrypi.org/documentati ... ecurity.md
Section "Install a firewall" could be what you are looking for.
itsacoolaccount
Re: SSH IP Filter
Sun Mar 18, 2018 11:47 pm
Fixed.
I just put the following into the end of /etc/ssh/sshd_config
AllowUsers *@127.0.0.1 *@192.168.0.*
Thanks anyways!
mfa298
Re: SSH IP Filter
Mon Mar 19, 2018 11:31 am
Fixed.
I would highly recommend reading through all the sections on the link fbe provided. Failure to do some of those could easily lead to your pi becoming compromised.
My additional recommendation for SSH is to change it's default port to something else. Whilst this is only security through obscurity it will stop the vast majority of automated scans that will fill the logs (I've seen thousands of such scans per day in the past).
Return to “Advanced users”
