Is it possible to use two Raspberry Pi computers together in such a way that the result is effectively one dual-core computer? If so, how would one go about implementing this?
My apologies if I don't use proper terminology, if I'm being unclear, if there's already a thread regarding this (I couldn't find it), or if I'm posing it in the wrong place. And please let me know if I'm doing any of those so I can correct it.
Re: using two Pis as one dual-core?
No, not really...
You can create what they're calling a >>>Bramble<<< -- a cluster of Raspberry Pis -- but it's not the same as having a multi-core CPU.
Here's one made from 64 Pis:
http://www.southampton.ac.uk/mediacentr ... uter.shtml
Ah well.. Thank you for replying! And I'm checking out the Bramble now.
Commonly referred to as a Beowulf cluster.
SELECT `signature` FROM `users` WHERE `username`='saintdev';
Empty set (0.00 sec)
a "cluster" of 2 Rpi would be called a circumference, surely
It turns out that a "cluster" (even of two; and I rather like the term "circumference" for 2 RPis!) is actually what I want to do. I want to learn how parallel computing works (clearly I have a long way to go) and be able to write code that I can actually test.
What exactly is a bramble/cluster of raspberry pis?
I understand it's parallel computing but how would you explain it in a simple manor?
If I were to connect my two pis, would I essentially have a 'faster' PI connected to 1 monitor?
Ex. double RAM/CPU?
Ex. double RAM/CPU?
That was really, really bad. So bad, that it was good! Well played.jaromanda wrote:a "cluster" of 2 Rpi would be called a circumference, surely
There are 10 types of people in this world. Those that understand binary, and those that don't.
No, it would not be for general use. But two or more Pis would have the potential to perform certain tasks faster than a single Pi IF the task lent itself well to parallel computing AND software was written for that task.ech0 wrote:If I were to connect my two pis, would I essentially have a 'faster' PI connected to 1 monitor?
From what I've read, a cluster of Pis or "Bramble" (or Beowulf cluster, whatever you call it) might be OK as an educational tool for learning more about parallel computing, but there are better solutions in terms of price to performance.
i.e. no existing consumer software will ever work faster on two Pis compared to one.
Nor any Linux GUI apps.
ghans
ghans
Kind of: SSI allows you to fool Linux into thinking that there is one dual-core Pi.tenebrescence wrote:Is it possible to use two Raspberry Pi computers together in such a way that the result is effectively one dual-core computer? If so, how would one go about implementing this?
I'd be willing to attempt a R-Pi distro using SSI, if you're interested and willing to help.
Matthew:out
- Contact: Website
Thats sounds good to me!!!ZirconiumX wrote:Kind of: SSI allows you to fool Linux into thinking that there is one dual-core Pi.tenebrescence wrote:Is it possible to use two Raspberry Pi computers together in such a way that the result is effectively one dual-core computer? If so, how would one go about implementing this?
Matthew:out
http://www.codeclinic.de
- Contact: Website
You already have a dual-core device. Your GPU runs in parallel with your CPU (Arm). It does depend on what you want to do, but you can get your GPU to do more than just graphics.
/Dextrus
/Dextrus
Have more FUN with your Pi. Visit www.pi-fun.com
