decuser
Is it normal to not see linux boot messages when connected to rpi (various versions) via serial cable?
Wed Feb 21, 2018 2:18 am
I am connecting to my pi(s) via a prolific 2303 cable and I eventually see a login, but no linux boot messages - I seem to recall being able to see these messages in the past, but I'm not sure now. I even tried rebooting with out disconnecting the cable and sure enough, I see the reboot message and then nothing until the login message:
raspberrypi login: pi
Password:
Last login: Thu Sep 7 16:17:20 UTC 2017 on tty1
Linux raspberrypi 4.9.41+ #1023 Tue Aug 8 15:47:12 BST 2017 armv6l
The programs included with the Debian GNU/Linux system are free software;
the exact distribution terms for each program are described in the
individual files in /usr/share/doc/*/copyright.
Debian GNU/Linux comes with ABSOLUTELY NO WARRANTY, to the extent
permitted by applicable law.
[email protected]:~$ sudo reboot
[ 97.011839] reboot: Restarting system
Raspbian GNU/Linux 9 raspberrypi ttyAMA0
raspberrypi login:
Is it possible to see the boot messages in real time (I know I can see them in retrospect via dmesg)?
Will
jdb
Re: Is it normal to not see linux boot messages when connected to rpi (various versions) via serial cable?
Wed Feb 21, 2018 2:16 pm
Remove the "quiet" parameter from /boot/cmdline.txt. This will give you kernel messages on the serial console.
Rockets are loud.
https://astro-pi.org
dgordon42
Wed Feb 21, 2018 4:36 pm
decuser wrote:I am connecting to my pi(s) via a prolific 2303 cable
I take it that the USB side is connected to the Pi. If so I don't think you can see the boot messages on a connected terminal as the Pi has to boot before the USB ports are up & running. I have tried adding "console=ttyUSB0,9600" to my '/boot/cmdline.txt' file, but I still don't see any boot messages on my old DEC VT320 Terminal which I connect to my Pi with a Prolific PL2303 Serial to USB Converter. with the USB side connected to the Pi.
Hope this helps,
Dave.
EDIT:
@decuser
Sorry, disregard. I was typing when you replied.
Dave.
decuser
Wed Feb 21, 2018 5:00 pm
@dgordon42, actually, I didn't even consider going the other way with a VT - awesome. I have a sudden urge to go grab a vt and do some pdp sims :).
Return to “Advanced users”
