craver2000
Converting docx to pdf, with python script
Sun Feb 18, 2018 5:56 am
I would like to convert a docx file to pdf on my raspberry pi (stretch OS)
What is the best way to do so using a python script on raspberry pi? I think libreoffice have functions like this, but I would like to automate the conversion, so the docx to pdf conversion is run on a python script. Are there python modules that allows me to do this? I appreciate any advice on this, thanks!
Re: Converting docx to pdf, with python script
Sun Feb 18, 2018 6:11 am
Libreoffice can do this in batch mode
libroffice --convert-to pdf myfile.docx
will create myfile.pdf
craver2000
Sun Feb 18, 2018 6:57 am
Thanks. As suggested, I've written this into my script:
def conversiontopdf():
	print("starting conversion to pdf")
	libroffice --convert-to pdf demo.docx
However, I get this error on terminal when I run the script.
  File "script.py", line 107
SyntaxError: invalid syntax
Any ideas why there would be a syntax error?
ghans
Sun Feb 18, 2018 7:56 am
You can't simply write commands into a Python script, especially if they are external
programs. This is a fundamental difference between bash scripts (which must support this) and other languages.
You need to use subprocess.
import subprocess
output = subprocess.check_output(['libreoffice', '--convert-to', 'pdf' ,'demo.docx'])
print output
ghans
craver2000
Sun Feb 18, 2018 8:28 am
Thanks ghans. I've implemented your code into my script.
	import subprocess
	output = subprocess.check_output('libreoffice', '--convert-to', 'pdf' ,'demo.docx')
	print output
I ran it and got:
  File "script.py", line 108, in conversiontopdf
  File "/usr/lib/python2.7/subprocess.py", line 212, in check_output
    process = Popen(stdout=PIPE, *popenargs, **kwargs)
  File "/usr/lib/python2.7/subprocess.py", line 339, in __init__
    raise TypeError("bufsize must be an integer")
TypeError: bufsize must be an integer
What does this bufsize error mean and how can I resolve it?
ghans
Sun Feb 18, 2018 8:34 am
Sorry, forgot the square brackets. Check my edited post.
craver2000
Sun Feb 18, 2018 8:47 am
Thank you, it works now!
Sun Feb 18, 2018 10:38 am
libreoffice --convert-to pdf myfile.docx
Edit: I should have spelt libreoffice correctly. Fixed now.
shanmukh
Tue May 22, 2018 6:47 am
I have used the following code it return's error.
I have libreoffice 6.0 installed in my fedora 24 os
profileId="somename"
def conversiontopdf(name):
output = subprocess.check_output(['libreoffice', '--convert-to', 'pdf' ,name])
print output
conversiontopdf(profileId+'docx')
error is:
Error: source file could not be loaded
rotwang
Tue May 22, 2018 10:43 am
print output
error is:
First, always enclose code, especially python, within <code> </code> tags. If you don't the indentation is lost, and as this is the only guide to structure for python, the result is text which is meaningless.
Second, if the filename you want to operate on is "somename.docx" then you will have to supply the "." somewhere, I'd suggest you change
conversiontopdf(profileid+'docx') to conversiontopdf)profileid+'.docx')
also add the name to the "print("starting conversion to pdf")"
Roger
Return to “Advanced users”
