fbe
Re: Booting from usb advice needed
Sun Feb 18, 2018 9:35 pm
There are other files in /boot that may be updated by package updates, raspi-config or other configuration tools. You want to boot from SD card and have the root filesystem on an USB device and I suppose you've got it working now with the usb-boot script. You should mount the boot partition of your SD card to /boot, because this is, where you are actually booting from if you leave the SD card in your Pi. Use the output of
lsblk -o NAME,PARTUUID,FSTYPE,SIZE
to identify the PARTUUID and modify /etc/fstab.
And be aware that the SD card and the USB drive are "married" now.
asandford
Sun Feb 18, 2018 10:34 pm
Haemogoblin wrote:
Sun Feb 18, 2018 9:16 pm
Does a kernal update happen during a sudo apt-get upgrade? or only through a raspi-update?
apt is the recommended way to get stable updates for the OS, kernel and bootloader files. raspi-update will get you the latest kernel, bootloader and RPF produced OS files but it might break things.
The OS and kernel are on / and the bootloader files are on /boot. There is a possibility that the /boot files might not get updated if the device that the Pi is booted from isn't the one that is mounted during update (moreso on net boot).
rpdom
Sun Feb 18, 2018 10:43 pm
Both. But you should use apt-get upgrade unless specifically told to use rpi-update.
PeterO
Sun Feb 18, 2018 11:41 pm
I would point out where that is wrong, but I'm not welcome here anymore !
PeterO
Interests: C,Python,PIC,Electronics,Ham Radio (G0DZB),Aeromodelling,1960s British Computers.
RonR
Mon Feb 19, 2018 12:36 am
Just tested...
Starting with a fresh copy of 2017-11-29-raspbian-stretch-lite.img on an SD card (no USB devices involved), running:
apt-get -y update
apt-get -y upgrade
apt-get -y dist-upgrade
does NOT update any /boot files NOR update any /lib/modules files or the kernel (it remains at 4.9.59)..
At this time, only rpi-update updates the firmware, /boot files, /lib/modules files and the kernel (to 4.14.18).
HawaiianPi
Mon Feb 19, 2018 12:14 pm
fbe wrote:
Sun Feb 18, 2018 8:06 pm
I wonder if a system with your configuration will survive a kernel update without manually synchronizing the boot partition on the SD card.
If both / and /boot are mounted to the USB device then kernel+firmware updates will also be applied to the USB device and not the SD card. There are two fixes for that (assuming no pure USB boot). One is to keep /boot on the SD card and only haved / on the USB boot device, the other is to only have bootcode.bin on the SD card.
fbe
Mon Feb 19, 2018 8:44 pm
I always wanted to try this method to boot but never did it before. So I:
  • Wrote the recent Raspbian image (2017-11-29) to an USB stick
  • Repartitioned a SD card (to prevent conflicting PARTUUID from a previous installed Raspbian), created a FAT32 filesystem
  • Moved the bootcode.bin from the first partition of the USB stick to the SD card
  • Plugged the SD card and the USB stick into my RPi 3B powered it on and...
it worked. Even the root partition on the USB stick was resized correctly. I could have copied the bootcode.bin instead of moving it, but i wanted to be sure, that the bootcode.bin on the SD card is used for booting.
This configuration doesn't suit if you want to boot your Pi later with more than one USB drive connected. So I
  • Moved all remaining files (except for System Volume Information, created by my Windows PC) from the first partition of the USB stick to the SD card
  • Modified /etc/fstab to mount the first (and only) partition on the SD card to /boot
  • Rebooted
... success. Having the whole boot partition on the SD card will ensure that updated bootcode.bin will be written to the right place too.
Finally, if i wanted to continue working with this setup i would remove the first partition on the USB stick or give it a fixed mountpoint in /etc/fstab to prevent automatic mount on login to the desktop.
RonR
Mon Feb 19, 2018 11:56 pm
I changed usb-boot such that it now mounts the BOOT partition of the SD card (/dev/mmcblk0p1) on /boot instead of the BOOT partition of the USB device (/dev/sdX1).
Anyone who used the original version of usb-boot may find it beneficial to modify the /boot line of the /etc/fstab file on the USB device to the following:
/dev/mmcblk0p1        /boot           vfat    defaults          0       2
asandford
Tue Feb 20, 2018 12:39 am
PeterO
Feel free to point out where you think I'm wrong, but my iscsi boot device says I'm correct.
As the bootserver isn't powered on when the iscsi booted device update, there is no way that the bootserver can be updated (the fact that it's mounted r/o is moot).
I welcome your comments as long as you can back the up.
fbe
Tue Feb 20, 2018 11:17 am
PeterO
The kernel modules are on / but I would bet the kernel is on /boot. But pointing that out would not change the recommendation, which partition should be mounted to /boot.
Return to “Advanced users”
