plotting data from an IMU sensor
Posted: Tue Jan 16, 2018 8:05 pm
by aelhadad
I am using raspberry pi 3 with an IMU sensor and i want to creat real time (live) data. I am using an MPU6050 sensor, the code is working fine and ican collect data. However, i could not plot the data as part of the code. I dont want to plot the data using STARTXWIN after the code is running, I want the plotting to be part of the code. Thanks
import threading
import struct
import bluetooth
class MotionTracker(object):
    """Class to track movement from MPU6050 Bluetooth device.
    def __init__(self, bd_addr, port=1):
        """Initialization for tracker object.
        Args:
            bd_addr (str) : Bluetooth address
            port (int, optional) : Port, defaults to 1
        Attributes:
            bd_addr (str): Bluetooth address
            port (int): Port
            sock (bluetooth.bluez.BluetoothSocket) : Bluetooth socket object
            acc_x (float) : acceleration in X
            acc_y (float) : acceleration in Y
            acc_z (float) : acceleration in Z
            angv_x (float) : angular velocity in X
            angv_y (float) : angular velocity in Y
            angv_z (float) : angular velocity in Z
            ang_x (float) : angle degrees in X
            ang_y (float) : angle degrees in Y
            ang_z (float) : angle degrees in Z
            temperature (float) : temperature in degrees celsius
            __thread_read_device_data (threading.Thread) : Read input thread
        self.bd_addr = bd_addr
        self.port = port
        self.sock = bluetooth.BluetoothSocket(bluetooth.RFCOMM)
        self.sock.connect((self.bd_addr, self.port))
        self.acc_x = 0.0
        self.acc_y = 0.0
        self.acc_z = 0.0
        self.angv_x = 0.0
        self.angv_y = 0.0
        self.angv_z = 0.0
        self.ang_x = 0.0
        self.ang_y = 0.0
        self.ang_z = 0.0
        self.temperature = 0.0
        self.__thread_read_device_data = None
    def start_read_data(self):
        """Start reading from device. Wait for a second or two before
        reading class attributes to allow values to 'settle' in.
        Non blocking I/O performed via a private read thread.
        self.__thread_read_device_data = threading.Thread(target=self.__read_device_data)
        self.__thread_read_device_data.is_running = True
        self.__thread_read_device_data.start()
    def stop_read_data(self):
        """Stop reading from device. Join back to main thread and
        close the socket.
        self.__thread_read_device_data.is_running = False
        self.__thread_read_device_data.join()
        self.sock.close()
    def __read_device_data(self):
        """Private method to read device data in 9 byte blocks.
        while self.__thread_read_device_data.is_running:
            data_block = self.sock.recv(1)
            if data_block == b'\x55':
                data_block_type = self.sock.recv(1)
                # Acceleration
                if data_block_type == b'\x51':
                    # Read 9 byte block
                    ax_l = self.sock.recv(1)
                    ax_h = self.sock.recv(1)
                    ay_l = self.sock.recv(1)
                    ay_h = self.sock.recv(1)
                    az_l = self.sock.recv(1)
                    az_h = self.sock.recv(1)
                    t_l = self.sock.recv(1)
                    t_h = self.sock.recv(1)
                    self.sock.recv(1) # Check sum, ignore
                    self.acc_x = struct.unpack("<h", ax_l + ax_h)[0] / 32768.0 * 16.0
                    self.acc_y = struct.unpack("<h", ay_l + ay_h)[0] / 32768.0 * 16.0
                    self.acc_z = struct.unpack("<h", az_l + az_h)[0] / 32768.0 * 16.0
                    self.temperature = struct.unpack("<h", t_l + t_h)[0] / 340.0 + 36.25
                # Angular velocity
                elif data_block_type == b'\x52':
                    # Read 9 byte block
                    wx_l = self.sock.recv(1)
                    wx_h = self.sock.recv(1)
                    wy_l = self.sock.recv(1)
                    wy_h = self.sock.recv(1)
                    wz_l = self.sock.recv(1)
                    wz_h = self.sock.recv(1)
                    self.angv_x = struct.unpack("<h", wx_l + wx_h)[0] / 32768.0 * 2000.0
                    self.angv_y = struct.unpack("<h", wy_l + wy_h)[0] / 32768.0 * 2000.0
                    self.angv_z = struct.unpack("<h", wz_l + wz_h)[0] / 32768.0 * 2000.0
                # Angle
                elif data_block_type == b'\x53':
                    # Read 9 byte block
                    roll_l = self.sock.recv(1)
                    roll_h = self.sock.recv(1)
                    pitch_l = self.sock.recv(1)
                    pitch_h = self.sock.recv(1)
                    yaw_l = self.sock.recv(1)
                    yaw_h = self.sock.recv(1)
                    self.ang_x = struct.unpack("<h", roll_l + roll_h)[0] / 32768.0 * 180.0
                    self.ang_y = struct.unpack("<h", pitch_l + pitch_h)[0] / 32768.0 * 180.0
                    self.ang_z = struct.unpack("<h", yaw_l + yaw_h)[0] / 32768.0 * 180.0
def main():
    """Test driver stub.
    try:
        session = MotionTracker(bd_addr="20:16:09:21:48:81")
        session.start_read_data()
        while True:
            print("ang_x:", session.ang_x, "ang_y:", session.ang_y, "ang_z:", session.ang_z)
    except KeyboardInterrupt:
        session.stop_read_data()
if __name__ == "__main__":
    main()
Re: plotting data from an IMU sensor
Posted: Tue Jan 16, 2018 10:18 pm
by SurferTim
How do you want to display it? I'm using a BNO055 IMU by Bosch. I'm displaying it on an aircraft instrument panel using pygame, but it isn't easy. I started by running the numbers first. If you are good with trig, the rest you can work out.
Can I post a jpeg image here (<100k)?
Posted: Wed Jan 17, 2018 2:06 am
by aelhadad
please
Posted: Wed Jan 17, 2018 8:23 am
by B.Goode
The Raspberry Pi Foundation have a Learning Resource that covers the use of matplotlib. This might meet your requirements.
https://www.raspberrypi.org/learning/vi ... worksheet/
If that is not suitable, using an internet search tool with the string Raspbian python plotting data will return a number of hits that might be helpful.
Posted: Wed Jan 17, 2018 12:10 pm
by SurferTim
I don't know what you mean by plotting. I display the output of my IMU on a panel. See attached photo. The turn part of the turn and slip isn't complete yet. All other instruments are operational.
I cheat tho. I'm using a Mega2560 to do all the device reads and calculations (needed AD converter for airspeed), and the USB connection to a RPi Zero with a wifi connection to an AP on a RPi3. That is where this display is.
Posted: Wed Jan 17, 2018 2:33 pm
by aelhadad
what I want to plot is the displacement vs time for X,Y,Z. REAL TIME PLOT though.
Posted: Wed Jan 17, 2018 2:36 pm
by SurferTim
aelhadad wrote: what I want to plot is the displacement vs time for X,Y,Z. REAL TIME PLOT though.
To where? Just to a file?
Edit: The instrument display I posted above is a 3D real time plot. The compass represent the X axis, and the attitude indicator is the Y and Z axis REAL TIME.
Posted: Wed Jan 17, 2018 3:15 pm
by aelhadad
http://mpmath.org/doc/0.19/_images/plot.png
I want the plot to update as long as the code running similar the heart rate plot in medical equipments.
Posted: Wed Jan 17, 2018 3:25 pm
by SurferTim
That doesn't look that difficult to me. You should be able to do that with pygame. The first step is displaying the xyz output (in text) from the IMU. That is the top line of my display. The first three numbers ("127 127 127") is my joystick output, and second three ("8 0 2") are the xyz Euler values from the IMU.
Now plot them like a heart rate monitor.
Bear in mind this is the "Advanced" section of the forum.
Posted: Sat Feb 10, 2018 6:49 pm
by nospam
http://dygraphs.com
has worked very well for me so far but I don't run at high update frequencies
