Radu79
How far in the boot process can the camera be used?
Tue Jan 16, 2018 12:45 am
I am trying to use a Zero board as a remote time lapse camera. Power is an issue (it will run on batteries), so I plan to start the Raspi either by a RTC or some Arduino, take a picture (with raspistill ), then shut down.
Any idea where in the boot process can I call raspistill?
bzt
Re: How far in the boot process can the camera be used?
Tue Jan 16, 2018 12:40 pm
Hi Radu79,
If I were you, I wouldn't code it in bare metal. Instead I would use the linux kernel, and override the init process with my shell script (which would do the necessary steps to run raspistill and finally call raspistill). See raspbian for example. On the first run, it executes a root partition resizer script, specified on the command line. But this is not the right forum for discussing that solution.
Cheers,
bzt
Tue Jan 16, 2018 12:48 pm
raspistill by default will only run under Raspbian anyway, not bare metal.
Radu79
Tue Jan 16, 2018 3:23 pm
I didn't mean to make it really bare metal, I do plan to use the Linux kernel. My question was, after loading the kernel (perhaps a lean kernel), how far in the init scripts would be a safe place to put raspistill ?
Tue Jan 16, 2018 3:37 pm
Probably best not in the baremetal forum then....
As for when, I doubt anyone has ever tested it - so trial an error might be the way to go. You need file system support, I think all the GPU requirements should be up and running before the kernel starts to boot.
mahjongg
Tue Jan 16, 2018 3:41 pm
Moved to advanced users.
Return to “Advanced users”
