aurelia
how do i activate my GPIO at boot with DT overlay?
Mon Jan 15, 2018 3:39 pm
Hello i've got a board connected to my raspberry pi 3 and according to the pin set on boot of the raspberry this shield reboot which is problematic. I need to be able to reset the board and control the pin. I cannot add an EEPROM to use the Raspberry shield system, so i tried to add an overlay to the DT to activate the gpio to an high output at boot but it doesn't work.
My overlay:
// Definitions for gpio module
/dts-v1/;
/plugin/;
	compatible = "brcm,bcm2835", "brcm,bcm2708", "brcm,bcm2709";
	[email protected] {
		target-path = "/";
		__overlay__ {
			test_board: test_board {
				compatible = "brcm,bcm2835";
				pinctrl-names = "default";
				pinctrl-0 = <&test_board_pin>;
				gpio-controller;
				gpios = <&gpio 27 0>;//GPIO active high is 0
				default-state = "keep";
				non-removable;
				#gpio-cells = <2>;
				status = "okay";
	[email protected] {
		target = <&gpio>;
		__overlay__ {
			test_board_pin: test_board_pin {
				status = "okay";
				brcm,pins = <27>;
				brcm,pull = <1>;//pull-down
				brcm,function = <1>; // out
				output-hight;
I compile it:
dtc -W no-unit_address_vs_reg [email protected] -I dts -O dtb -o test_board.dtbo gpio-test-overlay.dts
I add it to the overlay:
sudo cp test_board.dtbo /boot/overlays
I activate it:
dtoverlay=test_board
I reboot.
I check that it wok:
dtc -I fs /proc/device-tree > look1.txt
		[email protected] {
			compatible = "brcm,bcm2835-gpio";
			gpio-controller;
			#interrupt-cells = <0x2>;
			interrupts = <0x2 0x11 0x2 0x12>;
			phandle = <0xc>;
			reg = <0x7e200000 0xb4>;
			#gpio-cells = <0x2>;
			interrupt-controller;
			i2c1 {
				brcm,pins = <0x2 0x3>;
				phandle = <0x13>;
				brcm,function = <0x4>;
			test_board_pin {
				brcm,pins = <0x1b>;
				status = "okay";
				phandle = <0x4b>;
				brcm,pull = <0x1>;
				brcm,function = <0x1>;
				linux,phandle = <0x4b>;
				output-hight;
			spi0_pins {
				brcm,pins = <0x9 0xa 0xb>;
				phandle = <0xd>;
			sdhost_pins {
				brcm,pins = <0x30 0x31 0x32 0x33 0x34 0x35>;
				phandle = <0x17>;
			uart1_pins {
				brcm,pins;
				phandle = <0x11>;
				brcm,pull;
				brcm,function;
			i2s {
				brcm,pins = <0x12 0x13 0x14 0x15>;
				phandle = <0xb>;
	aliases {
		intc = "/soc/[email protected]";
		spi2 = "/soc/[email protected]";
		i2c1 = "/soc/[email protected]";
		i2c_vc = "/soc/[email protected]";
		spi0 = "/soc/[email protected]";
		thermal = "/soc/thermal";
		vchiq = "/soc/vchiq";
		sdhost = "/soc/[email protected]";
		aux = "/soc/[email protected]";
		gpio = "/soc/[email protected]";
		audio = "/soc/audio";
		dma = "/soc/[email protected]";
		soc = "/soc";
		leds = "/leds";
		mmc = "/soc/[email protected]";
		serial1 = "/soc/[email protected]";
		i2c_arm = "/soc/[email protected]";
		ethernet = "/soc/[email protected]/[email protected]/[email protected]";
		uart0 = "/soc/[email protected]";
		fb = "/soc/fb";
		i2c2 = "/soc/[email protected]";
		i2s = "/soc/[email protected]";
		spi1 = "/soc/[email protected]";
		usb = "/soc/[email protected]";
		i2c0 = "/soc/[email protected]";
		watchdog = "/soc/[email protected]";
		sound = "/soc/sound";
		mailbox = "/soc/[email protected]";
		uart1 = "/soc/[email protected]";
		random = "/soc/[email protected]";
		i2c = "/soc/[email protected]";
		serial0 = "/soc/[email protected]";
	chosen {
		bootargs = "8250.nr_uarts=1 bcm2708_fb.fbwidth=656 bcm2708_fb.fbheight=416 bcm2708_fb.fbswap=1 vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000  dwc_otg.lpm_enable=0 console=tty1 root=PARTUUID=436d5485-02 rootfstype=e
xt4 elevator=deadline fsck.repair=yes rootwait";
		kaslr-seed = <0x895630ca 0x6a72a22f>;
	test_board {
		gpios = <0xc 0x1b 0x0>;
		gpio-controller;
		status = "okay";
		phandle = <0x4c>;
		pinctrl-0 = <0x4b>;
		linux,phandle = <0x4c>;
		non-removable;
So the code is well integrated in the DT but the gpio is not exported, and when i export it, i can see that it's not set to output but input.
Can you help me to activate my GPIO?
thanks
Return to “Advanced users”
