Vanfanel
Raspberry Pi 3 CPU powersave feature question
Wed Jan 10, 2018 10:50 am
As you may know, at least on the X86 world CPUs enter so-called c-states to save power when they are idle.
Hence passing "idle=poll" to the kernel config parameters disables this option (some people do it to improve system jittering).
So, do the ARM cores on a Pi3 have this feature? Can it also be disabled via the "idle=poll" kernel parameter of other parameters?
Re: Raspberry Pi 3 CPU powersave feature question
Thu Jan 11, 2018 3:31 pm
None of the Raspberries have any power saving feature. It's not needed when it costs less than £5.00 per year to run one 24/365.
Vanfanel
Thu Jan 11, 2018 3:47 pm
Thanks, Dougie. I thought the ARM cores would have these states implemented anyway, since they are used in mobile setups, etc.
hojnikb
Sun Jan 14, 2018 8:52 am
Well, not a very good argument. You could have raspberry pi in a battery powered environment, where every W counts. Or in the case of rpi3, you could increase sustained performance by downclocking the cpu and thus having less heat to deal with.
+°´°+,¸¸,+°´°~ Everyone should have a taste of UK Raspberry Pie =D ~°´°+,¸¸,+°´°+
Rasberry Pi, SoC @ 1225Mhz :o, 256MB Ram @ 550Mhz, 16GB SD-Card, Raspbian
jahboater
Sun Jan 14, 2018 9:17 am
The governor does downclock the CPU's when idle.
At idle the Pi3 runs at 600Mhz, going up to 1200Mhz under load.
You can adjust either limit in /boot/config.txt
Return to “Advanced users”
