Pau.C
Steering Wheel Project!!
Tue Jan 02, 2018 10:48 am
Hi!!
I’ve just received "Waveshare 4inch HDMI LCD" . I bought this screen because I’m member of Formula Student Team at the University and our team is creating a Steering Wheel. For this reason, we need to simplify the HDMI pins. I want to know from the 19 pins which ones are useful HDMI pins in this screen “Waveshare 4inch HDMI LCD” to works good. In conclusion, I want to reduce HDMI electric cables (like: 13,14 and 18 pin. These pins im sure that are not necessary, but i need to reduce more.)
I need to reduce HDMI cables because i want to connect my raspberry to that screen with only one spiral cable. This spiral cable has to transmit HDMI and MICROUSB(power) interfaces like this (USB to Screen MICROUSB, and HDMI to screen HDMI) but with only one spiral cable:
Summary: (USB + HDMI) - (Spiral Cable) - (HDMI + MICROUSB)
(I have 2 of them with 15 electric cables inside)
Many thanks for your help.
6by9
Re: Useful HDMI pins?
Tue Jan 02, 2018 12:14 pm
https://en.wikipedia.org/wiki/HDMI
Pin 13 - CEC. It is supported by the Pi, but not critical.
Pin 14 - principally used for Audio Return Channel which isn't used on the Pi.
Pin 18 - 5V to power the EDID EEPROM. Provide a fixed EDID via config.txt and you don't need it or pins 15 or 16 (SCL and SDA).
The rest are required.
The data pairs should be carried on shielded twisted pairs with a 100 ohm characteristic impedance. If your cable just has 15 unscreened connections then I would expect some level of crosstalk issues.
Pau.C
Tue Jan 02, 2018 4:43 pm
mmmm i understand..
Then, I dont know how i can connect the raspberry and screen with only one spiral cable... in the internet there are spiral hdmi cable but only hdmi, no hdmi + power (microusb)...
In Formula Student Rules doesn't appear to have to go with a spiral cable, but i think is the best way to connect Steering Wheel in cockpit to raspberry inside the car...
Thanks!
6by9
Tue Jan 02, 2018 4:59 pm
Mount a Pi Zero on the steering wheel with a coiled network cable (eg http://www.cablescience.com/coils/elect ... eries.html) between the main intelligence and the wheel? Ethernet only requires two pairs, so there are two more pairs spare for power.
(A standard Pi might be easier as it then has the ethernet built in, whereas the Zero needs an external network adapter).
Nothing stopping you trying HDMI up the mismatched coiled cable. You may get away with it, or find that the crosstalk issues aren't a problem in your situation.
hippy
Tue Jan 02, 2018 10:21 pm
I would perhaps have gone for an RGB screen requiring just 5 wires or even composite requiring just three. And not worried about making it touch sensitive.
If you want touch sensitive HDMI I would put a zero in the steering wheel. Make that a remote GUI peripheral for the main system elsewhere and you are back to four wires again.
mahjongg
Wed Jan 03, 2018 12:04 am
practically all 19 Wires in a HDMI connection are necessary, see https://en.wikipedia.org/wiki/HDMI
Pau.C
Thu Jan 04, 2018 8:06 pm
It's a good idea but i have some doubts.
- When u say "main intelligence" u are talking, for example, about my pi 3? In that case, How can I transmit data between pi 3 and pi Zero? What Pi will have the python program to run the screen?
- If i connect external network in this way, i could use microUSB ports for screen power?? Or do i need an external MicroUSB power to supply Pi Zero? (Option 2, look down):
I dont know If I understood it well.
What option is the correct option?:
Option 1:
https://prnt.sc/hw4bn6
Option 2:
https://prnt.sc/hw4ccc
Pau.C
Thu Jan 04, 2018 8:13 pm
Thanks! In this case, i dont need touch sensitive in my screen of the steering wheel.
Thu Jan 04, 2018 8:20 pm
Option 1:
Option 2:
Depending on the amount of data you need to transfer and how fast, you could use a UART, or ethernet. Easy enough to provide communications that way. Where you put your program logic is up to you. Steering wheel Pi0 could just gather data and send it out to a Pi3 in car.
Pau.C
Re: Steering Wheel Project!!
Thu Jan 04, 2018 8:35 pm
The Pi3 will receive the data from the sensors of the car and a python program processes them and makes an interface appear on the screen (Done). Installing the PiZero I would like the pi3 to send all the processed data to the PiZero and that the PiZero shows the interface on the screen. Speed is very important.
This is my first version, i cant send python program because we are in a competition and this program is private (Sorry for that):
https://prnt.sc/hw4sjr
Thu Jan 04, 2018 8:37 pm
How much data do you need to send, and how quickly must it get there? You might get away with UART at 115kbaud which will be pretty easy to do.
Pau.C
Thu Jan 04, 2018 9:06 pm
How much data I dont know yet, but how quickly yes, 57600baud. But if I use UART, Can't I do "Option1" or "Option2" installation?
thagrol
Thu Jan 04, 2018 11:48 pm
If you're going to put a zero into the steering wheel to drive the screen, why not go for a zeroW and communicate with the Pi3 over wifi?
Note to self: don't feed the trolls
If you believe "L'enfer, c'est les autres" (Hell is other people) have you considered that it may be of your own making?
hippy
Fri Jan 05, 2018 2:04 am
If it's just a status display; speed, oil pressure, the usual 'car stuff' then you probably don't need to send a lot of data, nor that quickly.
If the sender is informed which screen is being shown it only needs to send the data used for that screen. Important data you can send every time. Less import data can be sent in two halves, one half each update. The rest of the data can be cycled through sending one or two items at a time. A bit like Teletext used to transmit pages.
Pau.C
Fri Jan 05, 2018 9:22 am
Because I think it's the slowest way to transmit data... And i need to put one spiral cable anyway to supply piZero and screen...
Parameters like speed or oil pressure are not necessary to transmit quickly, but RPM itself must be in real time...
Is a good idea transmit in different speed but i need to know how will I connect all devices, with UART, with Ethernet (WHY OPTION IS THE CORRECT, 1 OR 2??)...
Option 1:
Option 2:
Fri Jan 05, 2018 9:54 am
Option 1:
Option 2:
I think UART is going to be fast enough - at 115kbaud you can send 14k characters per second. Assuming 2 bytes/chars per RPM up you could update 7k times per second which is clearly massively over the top - you only need 60 updates/second at the most (screen refresh rate). Of course there are over heads for the protocol and the other data, but should be fine.
6by9
Fri Jan 05, 2018 10:03 am
Think more carefully about what "realtime" means in this context, and what latency is both practical and acceptable. An HDMI display is typically refreshed at 60Hz, so any rate greater than that is redundant.
How are you reproducing RPM on the display though? If as numerics, then the eye can't read the digits that fast, hence the smear of numbers on a stopwatch. Some form of graph can be interpreted by the brain faster, but also reduces the resolution of the data you need to transmit (256 steps on a graphical rev counter is probably sufficient).
Pau.C wrote:Is a good idea transmit in different speed but i need to know how will I connect all devices, with UART, with Ethernet (WHY OPTION IS THE CORRECT, 1 OR 2??)...
Option 1:
Option 2:
Not quite either as drawn.
Option 1 has no power going to the Pi0. Option 2 you haven't shown how you're looping the power through the Pi0 to the display.
(a) Check the current draw of your screen. The current available from the Pi3's USB ports is limited to 1.2A. If you're going to be drawing more than that, then T off your main power supply.
(b) At the steering wheel end, T the power connections and feed one set to the display, and one to the Pi0. That may be easiest if you feed power and ground up each of the two spare pairs, and then feed one pair to the Pi0 and one to the display.
Pau.C
Fri Jan 05, 2018 10:09 am
Should be fine yes!
Then, How can I do the installation?
Someone in this Forum has transmitted data from Pi3 to PiZero with UART?
thagrol
Fri Jan 05, 2018 1:20 pm
Err no. If wifi were slower we'd be using serial links for video streaming and gaming.
Pau.C
Fri Jan 05, 2018 2:13 pm
I can supply screen with GPIO Pins or with one PiZero microusb port. (PiZero MicroUSB - USB - Screen MicroUSB) or maybe MicroUSB to MicroUSB... What is better?
How can I know how much the screen consume?(No appear in instructions) and consume of PiZero?
My screen is this:
https://www.amazon.es/Waveshare-4inch-H ... are+4+inch
hippy
Sat Jan 06, 2018 11:48 pm
As others have noted; realtime does not mean fast transmissions or high bandwidth are required.
RPM and speed are likely just 16-bit values, with a refresh of 50Hz, that's 20ms per update, 40-bits of data via serial every 20ms; 2,000 baud.
But if UART serial does become a bottle-neck you can probably run some form of 'ethernet' Rx and Tx over just two wires.
Return to “Advanced users”
