Delipunch
Pi Zero Windows Drivers?
Sat Dec 16, 2017 11:32 pm
When I use the serial or ethernet usb gadget modes on the zero, windows tries to install device drivers, but can't find any. Does anyone know where to find them? Only a link to a OS version selection page is needed.
Names for the devices
g_serial:
Gadget Serial v2.4
g_ether:
RNDIS/Ethernet Gadget
(I use windows strictly for software compatibility reasons, and wine doesn't run everything I need well enough)
HawaiianPi
Re: Pi Zero Windows Drivers?
Sun Dec 17, 2017 10:54 am
What version of Windows are you using?
Are you sure you correctly added dtoverlay=dwc2 as a new line in config.txt, and modules-load=dwc2,g_ether to the end of the line in cmdline.txt? Make sure cmdline.txt is all one single line with no breaks. Make sure you use a pure text editor that doesn't embed hidden formatting codes.
If those files were edited correctly, the driver should be installed automatically by Windows 7 or later, but if it isn't you can try and install it manually.
This is how it's identified on my system.
And this should be the corresponding driver from Microsoft.
http://www.catalog.update.microsoft.com ... 8e439f90a2
Since it installed automatically on my system, I don't know if this will work, but the driver details match. ¯\_(ツ)_/¯
Delipunch
Sun Dec 17, 2017 12:04 pm
Win7 32-bit SP1 (I think it's SP1?)
I have made sure, I did edit with nano on the pi
It hasn't installed automatically, which is the problem.
That URL gives a 8DD0010 error on the site when I try to download it... I shall look for it elsewhere, however, and report back
HawaiianPi
Tue Dec 19, 2017 1:17 am
Sorry... that link used to work. Try here instead...
http://www.catalog.update.microsoft.com ... S%20Gadget
Return to “Advanced users”
