Ashnook13
Change GPIO pin state via command line
Mon Dec 11, 2017 6:03 am
I have a program running controlling a security camera. It records whenever it sees movement vis a PIR setting a gpio pin high. I want to be able to simulate the PIR detection whilst I am away from the camera by setting the GPIO pin high for a short time (or some other way???) This is done so I can take a video on demand.
Can this be done and if so how?
Thanks, Brian
joan
Re: Change GPIO pin state via command line
Mon Dec 11, 2017 8:14 am
Any number of ways.
  • write a small program interfacing with a GPIO library and make it executable.
  • write a shell script to use the sysfs interface to the GPIO.
  • use the wiringPi gpio utility.
  • use the pigpio pigs utility.
Ashnook13
Mon Dec 11, 2017 8:24 pm
Thanks for those suggestions, I have started looking at them.
Question, will they, or some of them, fool the program that is running to think there is a positive signal on one of the GPIO input signals as would be seen when the PIR shorts +5v to the GPIO input?
Thanks.
pcmanbob
Mon Dec 11, 2017 8:39 pm
First off you PIR sensor should not be shorting 5v to the gpio input pin , the PIR sensor should be outputting 3.3v. Connecting 5v to the gpio will damage you pi.
So having got that out of the way, the simple way to set up a remote trigger is to set another gpio pin to output and connect it the the input used for the PIR using a 1K resistor.
Now any time you want to remotely trigger you PIR/camera all you need do is drive this gpio output high for 1 second or how ever long you want.
Remember we want information.......................no information no help
The use of crystal balls & mind reading is not supported
Ashnook13
Mon Dec 11, 2017 8:45 pm
OK, Thanks again, you are right and it is actually the 3.3v from the GPIO bus, NOT 5v, my mistake, I am just running two wires from the PI to the isolated relay on the PIR.
Your output/1KR/input idea is a good one and I will implement this when I return home.
I am away for a little while and wondered if I could activate it from here so I can see the snow situation at home. Alternatively I will get someone to walk up the drive and trigger it!
Cheers.
Return to “Advanced users”
