deenigewouter
High pitched noise when fading LED's via PWM
Sat Dec 09, 2017 7:41 pm
I've been using the raspberry pi B Rev2 to control a RGB led strip containing 5050smd LED's. I've connected the strip to my raspberry pi with mosfets, one for each channel. I've also added a usb sound card to let my leds react to music. My amp and raspberry pi are connected to the input source via an audio splitter.
When I control the lights via PIGPIOD and set the LED's at full brightness, everything is fine and no noise is heard. However, when I set them at a lower brightness, for example with the command
pigs p 17 200
the corresponding color dims but a high pitched noise is emitted from the speakers connected to my amplifier. This is very annoying, as the software I use to let my LED's dance (LightshowPi) uses pwm fading to dim the LED's rather then switching them off entirely to create a nicer looking effect.
Is there any way to eliminate this high pitched noise? I've added a basic schematic to show what my setup looks like.
Thanks in advance!
PhilBr
Re: High pitched noise when fading LED's via PWM
Sat Dec 09, 2017 11:32 pm
I would try an electrolytic capacitor between vcc and ground on your board. Something like 100 microfarad 25 volt.
I guess that the pwm switching is putting noise back via the power supply.
Phil
mahjongg
Sat Dec 09, 2017 11:57 pm
MOSFET gates should not put a load on your GPIO pins (unless the gates are zener protected, and the zener voltage is actually below 3.3V, but that is a long stretch). You can test that by placing a say 10K resistor in series with the GPIO wires running to the gates.
so with no load on the GPIO's there should not be any voltage modulation on the power.
Still there could be some wiring issue with voltage modulation entering through the ground wire between the LED's and the PI, that ends up in the sound device, you could eliminate that by using opto-isolators between the GPIO's and the LED driver FETs.
davidcoton
Sun Dec 10, 2017 11:47 am
It could be that the PWM frequency is radiating from the LED strip. You may need to screen all the audio circuits so they don't pick it up (the sulution is really to avoid radiating the PWM frequency in the first place, but that might be tricky).
Signature retired
drgeoff
Sun Dec 10, 2017 11:02 pm
If you are doing what the drawing shows ie using the microphone input to that USB sound dongle, it is rather sensitive and will readily pick up the PWM emitted by wires and breadboard tracks.
tinkerBOY
Contact: Website Facebook
Sat Aug 31, 2019 4:02 am
Did you find any solution with the high pitch noise?
“Everything should be made as simple as possible, but not simpler.” Albert Einstein
Return to “Advanced users”
