SurferTim
Re: Assigning an IP to Respbarry Pi 2 Model B1.1
Fri Dec 08, 2017 12:42 am
Then my obvious question is: If no video, why a keyboard and mouse?
The obvious solution is plug that HDMI cable into a TV and see what is going on.
ankur_r
Fri Dec 08, 2017 2:08 am
Hi All,
I have stated I dont have any display...Therefore I can't say anything as I am not able to tell anything, I m again telling. What I did , in glimpse -
1 . Buyer rpi2, card, cable other required hardware .
2. With card reader , downloaded raspbian from website .
3. Burn IMG file in card....
4. Put in card , connecting , installed vnc and ssh at laptop
5. And trying to get communications.
Pl help...
Regards.
Ankur
rpdom
Fri Dec 08, 2017 5:46 am
Did you enable ssh on the Pi after writing the image to the card?
ankur_r
Fri Dec 08, 2017 6:08 am
Hi Rpdom,
I stated twice I am not able to perform any operation on RPI as i am not able to see any of its interface...
Regards.
Ankur
rpdom
Fri Dec 08, 2017 6:30 am
You need to enable ssh on the card before you put it in the Pi.
Plug it into a windows system (or whatever you used to create it) and make a file called "ssh" or "ssh.txt" in the first partition of the card. Then put it in the Pi and power up. SSH should then be enabled.
ankur_r
Fri Dec 08, 2017 6:34 am
can u kindly share any link or come with little more details of text file and process ?
regds.
ankur
rpdom
Fri Dec 08, 2017 6:44 am
ankur_r
Fri Dec 08, 2017 7:04 am
Following link is described for 2016 release , I am using 2017, you may refer second section first line...even after that i tried..and created ssh empty file in boot partition of card... but no improvement...
Terminal data -
[email protected]:~/Desktop$ ssh [email protected]
ssh: connect to host 192.168.3.201 port 22: No route to host
[email protected]:~/Desktop$ ifconfig
eth0 Link encap:Ethernet HWaddr f4:30:b9:d9:24:14
inet addr:192.168.3.100 Bcast:192.168.3.255 Mask:255.255.255.0
inet6 addr: fe80::f630:b9ff:fed9:2414/64 Scope:Link
UP BROADCAST RUNNING MULTICAST MTU:1500 Metric:1
RX packets:20 errors:0 dropped:0 overruns:0 frame:0
TX packets:119 errors:0 dropped:0 overruns:0 carrier:0
collisions:0 txqueuelen:1000
RX bytes:4206 (4.2 KB) TX bytes:18335 (18.3 KB)
lo Link encap:Local Loopback
inet addr:127.0.0.1 Mask:255.0.0.0
inet6 addr: ::1/128 Scope:Host
UP LOOPBACK RUNNING MTU:65536 Metric:1
RX packets:13569 errors:0 dropped:0 overruns:0 frame:0
TX packets:13569 errors:0 dropped:0 overruns:0 carrier:0
collisions:0 txqueuelen:0
RX bytes:1191368 (1.1 MB) TX bytes:1191368 (1.1 MB)
[email protected]:~/Desktop$ sudo systemctl enable ssh
sudo: systemctl: command not found
[email protected]:~/Desktop$ sudo systemctl start ssh
[email protected]:~/Desktop$ sudo apt-get install systemctl
Reading package lists... Done
Building dependency tree
E: Unable to locate package systemctl
[email protected]:~/Desktop$ man ssh
where these sudo systemctl command needed to be run.....my ssh is enabled ...is it for rpi board interface ??
kindly help...
regds.
ankur
drgeoff
Fri Dec 08, 2017 10:08 am
1. Remove power from the RPi and remove the SD card.
2. Put the card in your Ubuntu laptop and use the dd command to write the Raspbian image to the card..
3. After the dd command returns with what it has done, wait a few seconds and remove the card from the laptop.
4. Re-insert the card into the laptop. Ubuntu should show two drives on the card. You need to do the following two operations in the root directory on the smaller size drive - the one that contains config.txt and cmdline.txt and many others.
5. Create a file with name ssh. It can contain anything, even a single character or nothing at all.
6. Use a text editor to open cmdline.txt. At the end of the existing line (NOT a new line) add a space and
ip=192.168.3.201
and save the file.
7. Safely eject the card.
8. Put the card in the RPi.
9. Connect RPi to laptop with an ethernet cable.
10. Set your laptop to have an IP address 192.168.3.200.
11. Apply power to the RPi and confirm it is booting by observing the green LED flickering for 10s of seconds.
12. Open a terminal window on the laptop and type 13. At the password prompt enter
raspberry
ankur_r
Fri Dec 08, 2017 12:36 pm
Hi All,
Thanks for your all help... Now I am able to log in. I got the prompt.
But tell me 1 point...
Do I again and again need to create ssh file, in the boot partition of card as it is been deleted at the time of booting ?? Is there any alternative of this ??
Regards.
Ankur
klricks
Fri Dec 08, 2017 1:45 pm
...Do I again and again need to create ssh file, in the boot partition of card as it is been deleted at the time of booting ?? Is there any alternative of this ??
No you do not need to create the file ssh file again unless you reinstall the OS again.
Now you can enable VNC by using the config utility via ssh
sudo raspi-config
Unless specified otherwise my response is based on the latest and fully updated Raspbian Stretch w/ Desktop OS.
ankur_r
Sat Dec 09, 2017 12:20 am
Now I have enabled vnc , spi, i2c like all interfaces with help of https://www.raspberrypi.org/documentati ... /README.md
To get vnc graphical interface , local setting is requested to be set ,
On laptop I m having following parameter to input -
1. Vnc host: Display
2. VNC Password
3. Proxy gateway
4. Remote ssh command
I given following values
1. 192.168.3.201
2. raspberry
3. 192.168.3.1 the gateway I given in me Ethernet connection on which ssh is connected .
4. Remote command .... Not able to decide .
On hitting connect some interface is displaying but none graphics interface is displaying ?
Whats more I needed to be done to get it's workable setup....?
How its internet will work ....? Where I can work with command like sudo apt-get install ... Downloading etc...
Pl help little more so that I can initiate my exercise further ...
Ankur
HawaiianPi
Sun Dec 10, 2017 10:16 am
Why aren't you just connecting your Pi2 to your router with the Ethernet cable?
ankur_r
Sun Dec 10, 2017 1:00 pm
Its not possible coz i m using wifi from public router. I have option to take interface on laptop. I have enabled vnc on rpi2....as per prescribed process.... but at other hand on ubuntu 12.04.5 LTS, I am not able to real vnc...
Can anyone help me with step by step process , some weblink or some other article ?
Regards.
Ankur
Sun Dec 10, 2017 2:31 pm
Regards.
Ankur
https://www.raspberrypi.org/blog/get-ba ... c-connect/
adieu
My other Computer is an Asus CS10 ChromeBit
SurferTim
Sun Dec 10, 2017 2:40 pm
If you are using Ubuntu, install and run nmap to see if your RPi shows up on the network.
sudo apt-get install nmap
nmap 192.168.3.0/24
Return to “Advanced users”
