JimFram
GPS Simulator/Emulator
Sat Nov 18, 2017 7:39 am
I am in need of a GPS Simulator for use in a underground location where a GPS signal is required for the device to work. I have been using devices that I have located from the internet although these GPS simulators are >$2,900-$32,0000. Can I somehow develop a GPS simulator that will generate four (4) GPS signals and program the Pi with a known location? The device needs to generate a GPS L1 RF signal 1575.42 MHz at a signal level of approx. -105dbm.
Any help and/or advice would be greatly appreciated.
Thanks!
Jim
topguy
Re: GPS Simulator/Emulator
Sun Nov 19, 2017 10:57 pm
The Pi itself doesn't have GPS so you would have to add a GPS device anyway, but I dont understand what you are trying to do.
- Are you still going to try to use GPS to navigate underground ?
- Or do you just need to trick the Pi that it has a GPS signal ?
The Pi is going to read NMEA data from the GPS you will connect to it, but NMEA data is just text that is very easy to simulate.
ghans
Mon Nov 20, 2017 11:09 am
OP doesn't want the Pi to emulate a GPS dongle. OP wants the Pi to emulate a
GPS satellite ...
I assume OP has a bunch of cheap GPS navi systems lying around which would be totally
useful if there was a way to use them in OPs underground cave complex.
If i had to decide between designing a reliable "outdoor" navigation system and a GPS transmitter i would opt for a map and a compass.
ghans
topguy
Mon Nov 20, 2017 12:06 pm
hm.. yeah that might make more sense.
Understanding that the location a GPS is reporting, comes from the minute differences in time the signal from each satellite reaches the receiver, and that the receiver also needs data about where each of the 24 satellites are at any moment in time. One can understand why these simulators costs what they do.
Depending on how deep his Batcave is, you can get GPS repeaters a bit cheaper: https://webstore.tri-m.com/gps-equipmen ... eater-kit/
hippy
Mon Nov 20, 2017 1:22 pm
GPS satellite ...
In fact needs to generate the signals to fake a small, four satellite, constellation looking at the OP.
It is not my area of expertise and I would guess it's a pretty specialised field. I would expect it's one of those cases that if it were easy or cheap to do then people would be doing that. A quick search of t'internet did not show up any homebrew GPS transmitters.
topguy
Mon Nov 20, 2017 3:26 pm
Just think about the possible security/safety implications if this was easy to do.
hippy
Mon Nov 20, 2017 4:55 pm
I dug around and couldn't find anything low priced, not even systems using off-the-shelf SDR's. It's a whole new ballpark to hijacking heart rate monitor watches and faking radio time code signals which only need a coil of wire and a $1 micro.
I think we are safe from rogue CubeSats and miscreants on motorway bridges at least for now :D
beta-tester
Mon Nov 20, 2017 8:20 pm
Thanks!
Jim
sounds a little bit like "GPS Spoofing"... :?
is there no way to bypass the GPS receiver and feet the NMEA data to the device that is directly behind the GPS receiver?
so you do not need that fancy expensive high frequency stuff. then you only need to cut trace on the PCB of the GPS module serial output and inject simulated serial data to the consuming device.
{ I only give negative feedback }
RPi Model B (rev1, 256MB) & B (rev2, 512MB) & B+, RPi2B (1GB), 64GB microSDXC1 class 10, HDMI 1920x1080, keyboard-mouse-combo (wireless), PiCamera, ethernet-cable, 5V/1.2A power supply, Wifi dongle (rt5370)
rosbif69
Sat Nov 25, 2017 4:38 pm
Funnily enough, I'd like one too. :-) I want to test my GPS programs in python, without having to leave the window open.
I've seen this:
https://www.youtube.com/watch?v=VqLSKPYKeXU
But the information isn't too detailed. It does seem to be near to what the OP is requesting though.
hippy
Sat Nov 25, 2017 8:04 pm
I've seen this: https://www.youtube.com/watch?v=VqLSKPYKeXU
That is using Bluetooth to provide faked location data for the mobile phone, rather than providing a faked satellite signal which the phone's GPS receiver can use. It is a clever idea but not quite the same.
It might be a solution for the original poster, but perhaps not; they haven't detailed what their receiving equipment is.
Return to “Advanced users”
Who is online
Users browsing this forum: Google [Bot] and 23 guests
