G109B
PHP gives segmentation fault on simple fopen call in Stretch
Thu Nov 16, 2017 12:38 pm
I have a php script running from an apache2 web page under Stretch where
$myfile = fopen("log","w");
causes a segmentation fault.
This code runs without problem on Wheezy, is there something I am missing ?
Re: PHP gives segmentation fault on simple fopen call in Stretch
Thu Nov 16, 2017 2:13 pm
Why not use the php logging function http://php.net/manual/en/function.error-log.php that will get written to /var/log/apache2/error.log (unless you change the logging file in /etc/php/7.0/apache2/php.ini).
Microprocessor, Raspberry Pi & Arduino Hacker
Mainframe database troubleshooter
MQTT Evangelist
Twitter: @DougieLawson
2012-18: 1B*5, 2B*2, B+, A+, Z, ZW, 3Bs*3, 3B+
G109B
Thu Nov 16, 2017 2:27 pm
Yes Dougie, this is exactly where I have found the message "Segmentation Fault".
Otherwise you are left non-the-wiser if you only look at the resulting blank web page.
Thu Nov 16, 2017 2:44 pm
That's not the right way to log stuff. You got lucky that it worked with php5 on Wheezy.
The way to log stuff from your PHP program is
error_log("stuff to log to /var/log/apache2/error.log", 0);
MQTT Evangelist
G109B
Thu Nov 16, 2017 7:18 pm
Er, I think we are losing the plot here. My code was an example of an fopen call which didn't return, so calling error_log was not an option because it had core-dumped by then.
apache kindly left the message in apache2/error.log.
Return to “Advanced users”
Who is online
Users browsing this forum: Imperf3kt and 14 guests
