dom
Re: Moving Linux kernel to 4.14
Tue Feb 13, 2018 3:08 pm
paul433 wrote:
Tue Feb 13, 2018 3:03 am
Running Headless or putting dwc_otg.fiq_enable=0 and dwc_otg.fiq_fsm_enable=0 on the command line also reduce/eliminate the kernel panics.
Have you ever seen the panic with dwc_otg.fiq_enable=0 and dwc_otg.fiq_fsm_enable=0 ?
It makes a big difference to identifying where the bug is if the result is panic is eliminated, compared to panic is reduced.
dom
Tue Feb 13, 2018 3:13 pm
However the PREEMPT and PREEMPT_RT kernels are still showing the crash as posted above.
So are you using our kernel tree unpatched, or is that a tree modified with RT patches?
The RT patches are not supported by us and not expected to work with fiq based USB driver.
paul433
Tue Feb 13, 2018 3:56 pm
We have seen issues with all 4.14.y kernels. RPI tree unpatched, RPI tree with changing config to Voluntary Preemption, and then a full RT patch. I understand that you don't support the RT patches. The RT patch was something new that we were trying out. But the other 2 kernels worked completely fine under 4.9.y
This is the type of problem that is moving around, and as soon as you think X setting fixes the problem, the problem comes back. As soon as I typed the message in the forums about the unpatched kernel being ok.....one of the beta testers reported back that it was having the problem again.
We just started to investigate FIQ settings over the weekend, I'll have to setup some more tests with the unpatched kernel. This error only happens during boot. As my previous messages have noted, there are a lot of conditions/settings that affect it. Eliminate is tough thing to say, but normally around 200 reboots without an error I think we could call it good.
jdb
Wed Feb 14, 2018 12:37 pm
Regarding the crash on boot with USB, there's a clue in what each CPU is doing.
CPU1 just entered the FIQ handler, and CPU2 is in dwc_otg_driver_init(). I think there may be some racy behaviour between taking an interrupt too early and the coherence of the driver state.
I note that the USB register offset (xx98xxxx) appears nowhere in the stack or in the register dump. In a comparable dump from a locally compiled kernel (offsets probably completely munged) the code is approximately:
1266            gintsts.d32 = FIQ_READ(state->dwc_regs_base + GINTSTS);
   0x004c2d2c <+88>:    ldr     r3, [r4, #24]
   0x004c2d30 <+92>:    ldr     r6, [r3, #20]
1267            gintmsk.d32 = FIQ_READ(state->dwc_regs_base + GINTMSK);
   0x004c2d34 <+96>:    ldr     r10, [r3, #24]
So in this case, at least 1 register should have a recognisable virtual address of the register space.
Rockets are loud.
https://astro-pi.org
paul433
Thu Feb 15, 2018 3:29 pm
Further testing
Setting dwc_otg.fiq_enable=0 and dwc_otg.fiq_fsm_enable=0
Unpatched rpi kernel (SMP kernel) - two different systems with over 500 reboot cycles without crash.
I see this commit in the kernel tree. https://github.com/raspberrypi/linux/co ... 5978fe6280
I'll build this tonight and test it out.
jdb
Thu Feb 22, 2018 1:08 pm
Latest rpi-update contains a potential fix for the crash on boot.
Rockets are loud.
paul433
Thu Mar 15, 2018 1:04 pm
Kernel 4.14.21 seemed to be really stable, 4.14.24 we started seeing these kernel panics again. Seems that we have not round the race condition that is causing the problem.
manawyrm
Thu Mar 15, 2018 5:36 pm
Have updated the new Raspberry Pi 3B+ to the 4.14 kernel -- works nicely! :)
[email protected]:~# uname -a
Linux raspi3bp 4.14.26-v7+ #1099 SMP Wed Mar 14 14:59:28 GMT 2018 armv7l GNU/Linux
jdb
Thu Mar 15, 2018 7:38 pm
Is the dmesg log/stacktrace any different?
Rockets are loud.
paul433
Sat Mar 17, 2018 4:32 pm
Looked similar, but that's far from conclusive. I didn't have the pause_on_oops set on the command line when it happened. And of course, now it is being elusive. I'll keep watch and post a full trace if I see it.
darksky
Mon Mar 26, 2018 8:07 am
dom wrote:
Tue Nov 14, 2017 2:25 pm
Update with:
sudo rpi-update
and reboot. Ideally nothing much will change.
Please report if there are any regressions compared to the 4.9 kernel.
I just flashed XBian_Latest_rpi3.img and am booted into xbian on my RPi3. It's running 4.9.87+. Which package provides the script you reference above?
dom
Mon Mar 26, 2018 11:09 am
rpi-update is designed for raspbian and the raspbian package is rpi-update.
I believe xbian uses a custom kernel so running rpi-update would likely be a bad idea. You should ask on xbian forums.
ShiftPlusOne
Wed Mar 28, 2018 1:53 pm
The raspberrypi-kernel package apt has been updated to 4.14 now.
PeterO
Wed Mar 28, 2018 9:52 pm
OOOooo... Shiney :-)
[email protected]:~ $ uname -a
Linux raspberrypi 4.14.30-v7+ #1102 SMP Mon Mar 26 16:45:49 BST 2018 armv7l GNU/Linux
PeterO
beta-tester
Wed Mar 28, 2018 10:14 pm
nice... :D
is it way too early to ask what kernel version will be next? :oops:
(4.15 or 4.16)
RPi Model B (rev1, 256MB) & B (rev2, 512MB) & B+, RPi2B, RPi3B, RPi3B+, RPiZeroW, ...
sharukins
Thu Mar 29, 2018 5:58 am
nice... :D
(4.15 or 4.16)
probably the next LTS version, (4.19 maybe)
hommar
Thu Mar 29, 2018 8:52 am
nice... :D
(4.15 or 4.16)
The raspberrypi-kernel package apt use LTS always
LTS will be 4.19 possible
(becouse 4.4, 4.9, 4.14 is LTS)
PS Why git clone previous version?
git clone --depth=1 https://github.com/raspberrypi/linux
kneekoo
Thu Mar 29, 2018 9:38 am
Will we get a blog article about the new kernel? Is there anything notable about it? Any improvements, RAM usage differences, support for new devices, etc.
6by9
Thu Mar 29, 2018 9:39 am
The default branch on https://github.com/raspberrypi/linux/ hasn't been updated, that's all. I'll nudge relevant people.
dom
Thu Mar 29, 2018 10:19 am
Should be updated now.
dom
Thu Mar 29, 2018 10:33 am
Probably best to follow the four links in the first post. For most users there will be no visible change. Everything should work as before,
with no significant change in performance or memory usage.
There are many drivers added for new hardware, bug fixes, new features and security improvements, but these are upstream changes rather than things we are responsible for, and are best described by upstream sources.
kneekoo
Thu Mar 29, 2018 11:21 pm
Thanks for your reply. I won't add the same information here, but rather the link to my comment on the blog post about MagPi 68.
The on thing that is new and doesn't seem to work is the vc4-hdmi entry in the audio applet menu, which doesn't seem to do anything if you click on it. Can anyone confirm this feature to appear after the upgrade to kernel 4.14? Does it work for anyone?
dom
Fri Mar 30, 2018 10:47 am
Can you explain exactly what you mean by the audio applet menu? Where is this menu, what did it used to do and how has it changed?
tvjon
Fri Mar 30, 2018 11:19 am
@kneekoo
If you mean this:
(see attached jpeg. I have no javascript on this browser so it won't go inline)
I also see no effect on omxplayer for example.
I haven't noticed this before as I almost always specify the destination in the omxplayer statement, for example:
omxplayer -o alsa:pcm.default ...
I've just tried setting the applet to HDMI & simply used:
omxplayer music.mp3
& it played from the HDMI monitor.
Changing the applet to Analog
restart:
omxplayer music.mp3
still played through the monitor.
kneekoo
Fri Mar 30, 2018 3:26 pm
This is the sound applet menu, and clicking vc4-hdmi has absolutely no effect, other than closing the menu.
Return to “Advanced users”
