KingOfLostFools
Re: Moving Linux kernel to 4.14
Wed Jan 10, 2018 6:09 am
One of my Raspberry PI's is in a really poor location for WiFi (not my network, so I can't fix or adjust it).
It operates well and the apt-get update and apt-get upgrade commands don't phase it at all, but the sudo BRANCH=next rpi-update fails multiple times during the download of the second stage with "gzip: stdin: unexpected end of file".
Even though it has downloaded a big chunk of the file, whenever I reissue the command it starts stage two back from the beginning again (and usually fails again when the wifi dips out)
Are there any options to prevent this, ensure the second stage continues from where it left off or whatever?
Time is the fire in which we burn - Delmore Schwartz
algorithm
Thu Jan 11, 2018 10:30 am
I'm pretty sure this is not related to the BRANCH=next topic of this thread, but yes, I have had that same problem over the holiday. It might be down to spotty wifi, like you say, but also like you, it only fails on rpi-update never on apt-get upgrade. I wondered if the specific servers were busier than usual.
dom
Thu Jan 11, 2018 11:44 am
paul433 wrote:
Tue Jan 09, 2018 5:04 pm
How is the testing going? Has there been a decision made to make the transition official?
Seems to be no major issues. Moving to the master branch of rpi-update should happen pretty soon.
KingOfLostFools
Thu Jan 25, 2018 4:57 am
I've followed that link and I don't even understand what it is that you are linking to.
runboy93
Thu Jan 25, 2018 9:54 pm
4.9.y VC4 status seem to be frozen, and now work continues on 4.14.y (3 hours ago, changes added to rpi-update firmware kernel 4.14.15)
Fri Jan 26, 2018 9:47 am
Hence the title of this thread?
runboy93
Fri Jan 26, 2018 11:41 am
Yeah, but let's hope we see it in near future like first post says.
Fri Jan 26, 2018 6:36 pm
And the reason that 13 out of 14 raspberries are running 4.14.15. Three 3Bs are also running the beta version of the WiFi firmware.
Beware that this is a game for experts only, it's for the folks who can get a dead Raspberry running again in twenty minutes rather than twenty hours.
cjan
Sat Jan 27, 2018 3:30 am
cjan wrote:
Wed Nov 15, 2017 12:04 am
enable FKMS boot fail, black screen.
after 2 months test again 4.14.15, black screen still.
HiassofT
Sat Jan 27, 2018 3:00 pm
FYI: Eric Anholt held a rather interesting talk about VC4 driver development a this week's linux.conf.au. It's up here on youtube: https://www.youtube.com/watch?v=hNeq-iG9pfc
so long,
Hias
paul433
Sat Jan 27, 2018 11:50 pm
Anyone seeing Kernel panics at boot? It's very random and it seems to come and go. The final message is Kernel panic - not syncing - attempted to kill idle task which I know is pretty generic.
But when it happens, the kernel is crashing before the serial console comes up, so all I can see is the partial error that is still on the monitor.
EDIT: I rebuilt the kernel, enabling some built in fonts so that I could get more on the screen. It is crashing when detecting/setting up the usb controller. See Attached image. While this is a PREEMPT built kernel, we have seen this type of crash on the SMP kernel. This image is also using the current firmware->next branch. Most of the time, the system boots just fine, and will run just fine.
Normally we run initial_turbo=60 in the config.txt, but removing it does appear to help.
dom
Tue Jan 30, 2018 1:32 pm
Are you overclocking? Does "vcgencmd get_throttled" return a non-zero value (when booting succeeded perhaps after running something that stresses Pi).
paul433
Tue Jan 30, 2018 6:33 pm
No overclocking. I'll have to add vcgencmd to check on throttling. we don't normally include this in our packages. This is happening on many different systems across our dev team (RPI2B, RPI3B) some with the rpi 7" display others HDMI monitors connected to troubleshoot, and various Audio configurations (onboard audio or various i2s dacs). Once running, we have not seen any issues. And we have not seen this situation under 4.9.y kernels.
I should note that we have the scaling governor defaulted to performance in the kernel as well.
A couple other observations
1) Frequency of error is higher when warm booting, but still can go 15-20 reboots without seeing the error.
2) As Noted, removing initial_turbo=60 did help, but did not eliminate the issue
3) Using a different io scheduler changes the behavior (deadline is default)
4) Boot media has no effect (i.e. rpi3B booting from USB stick )
Roken
Tue Jan 30, 2018 8:59 pm
I've been using 4.14 for a while on an Arch Desktop without issues. 4.15 dropped in today, which at the moment is working, but not long enough for issues. However, 4.15 introduces support for the Pi touchscreen (not an issue for my headless use, but probably of interest to some). - https://www.phoronix.com/scan.php?page= ... r-Exciting
I'm considering buying another with a powerbank and touchscreen, and see how it compares to my tablet.
paul433
Fri Feb 02, 2018 3:33 pm
Just a as a followup, through various testing, vcgencmd get_throttled always returns 0.
I also noted that the Rasbian kernels are compiled with a different Cross Compiler than noted here (https://www.raspberrypi.org/documentati ... uilding.md) So I have switched to that gcc 4.9.3 based compiler.
I have not been able to replicate on raspbian. But our OS(piCore) is purely running in RAM, so root=/dev/ram0 and we are loading the initrd with the config.txt
initramfs intrd.gz followkernel
Is there anything that we can do to get more debug info?
dom
Mon Feb 05, 2018 9:23 pm
I believe fkms is fixed in latest update (4.14.17). If you use this then please give it a test and report here.
I expect we'll be pushing 4.14 to default (master) branch of rpi-update this week.
runboy93
Mon Feb 05, 2018 11:51 pm
Very good news :)
dom
Fri Feb 09, 2018 6:59 pm
4.14 is now on the master branch of rpi-update.
sudo rpi-update
is enough to get the 4.14 kernel.
memos.electron
Sun Feb 11, 2018 12:21 pm
Good news for 4.14.18 for arm64. Running on 64bit kernel with only one problem on WiFi. The brcmfmac and brcmutil not loaded at boot time. Tried to load them manually without errors and didn't find the wlan0 interface with sudo ifconfig. I know networking must be restarted and after sudo sysctl networking restart still the same results.
This is the script I 've made for the build process:
#!/bin/bash
KERNEL=kernel8
LINUX_SOURCE_DIRECTORY=linux-rpi-4.14.y
LINUX_BUILD_DIRECTORY_PREFFIX=linux-rpi
RPI_KERNEL_VERSION=4.14.18-v8
OUTPUT_DIR=clone
BUILD_OUTPUT=$LINUX_BUILD_DIRECTORY_PREFFIX-$RPI_KERNEL_VERSION
cd $LINUX_SOURCE_DIRECTORY
make ARCH=arm64 O=../$BUILD_OUTPUT CROSS_COMPILE=aarch64-linux-gnu- bcmrpi3_defconfig
make ARCH=arm64 O=../$BUILD_OUTPUT CROSS_COMPILE=aarch64-linux-gnu- -j4
sudo make ARCH=arm64 O=../$BUILD_OUTPUT CROSS_COMPILE=aarch64-linux-gnu- INSTALL_MOD_PATH=../$OUTPUT_DIR/rootfs modules_install
cd ..
sudo rm $OUTPUT_DIR/rootfs/lib/modules/$RPI_KERNEL_VERSION/build
sudo rm $OUTPUT_DIR/rootfs/lib/modules/$RPI_KERNEL_VERSION/source
sudo cp $BUILD_OUTPUT/arch/arm64/boot/Image $OUTPUT_DIR/boot/$KERNEL.img
sudo cp $BUILD_OUTPUT/arch/arm64/boot/dts/broadcom/*.dtb $OUTPUT_DIR/boot
[ ! -e $OUTPUT_DIR/boot/config.txt~ ] && sudo cp --preserve=all $OUTPUT_DIR/boot/config.txt $OUTPUT_DIR/boot/config.txt~
#[ ! -e $OUTPUT_DIR/boot/cmdline.txt~ ] && sudo cp $OUTPUT_DIR/boot/cmdline.txt $OUTPUT_DIR/boot/cmdline.txt~
sudo cp --preserve=all $OUTPUT_DIR/boot/config.txt~ $OUTPUT_DIR/boot/config.txt
sudo bash -c 'echo "
# For 64bit to work
arm_64bit=1
" >> '$OUTPUT_DIR'/boot/config.txt'
#sudo cp $OUTPUT_DIR/boot/cmdline.txt~ $OUTPUT_DIR/boot/cmdline.txt
#sudo bash -c 'echo "dwc_otg.lpm_enable=0 console=ttyAMA0,115200 console=tty1 root=/dev/mmcblk0p2 rootfstype=ext4 elevator=deadline fsck.repair=yes rootwait" > '$OUTPUT_DIR'/boot/cmdline.txt'
sudo rsync -aur --rsync-path "sudo rsync" $OUTPUT_DIR/boot/* pi@beesNODE:/boot
sudo rsync -aur --rsync-path "sudo rsync" $OUTPUT_DIR/rootfs/lib/modules/$RPI_KERNEL_VERSION pi@beesNODE:/lib/modules
Please tell me if there is something wrong.
nixy82
Mon Feb 12, 2018 10:50 am
Hi
We're running a CM3 on a custom carrier board we've had for a few years now.
Has been running quite happily up to 4.9.75, no problems. All Solid.
I've just done a rpi-update running on Jessie to test out the new 4.14 kernel and the system hangs on next boot up :
https://gist.github.com/anonymous/55a8b ... b3f61db1c1
These look more interesting from a "going bang" perspective :
https://gist.github.com/anonymous/16b43 ... 046169804a
https://gist.github.com/anonymous/b36a2 ... ffc0584462
What can I do to assist with debugging this?
Andrew.
6by9
Mon Feb 12, 2018 11:13 am
Hi
To avoid duplication of effort, this has been raised on Github too. Probably easiest to keep working there.
nixy82
Mon Feb 12, 2018 11:16 am
Yes that's what I figured ;-)
6by9
Mon Feb 12, 2018 1:43 pm
Minor realisation - 4.14 switches to the upstream version of the V4L2 driver, and that uses CMA for all the allocations. If asking for large images then you may have an issue as the default CMA heap is only 8MB.
Adding "cma=48M" to the start of /boot/cmdline.txt should suffice for now, but I'll discuss with others what the best solution is there. (CMA is going to become more and more relevant very soon, so we need to answer the question sensibly anyway).
edit: scrub that. We just have a bastard love child.
https://github.com/raspberrypi/linux/bl ... Kconfig#L6
select VIDEOBUF2_VMALLOC
https://github.com/raspberrypi/linux/bl ... mera.c#L20
#include <media/videobuf2-vmalloc.h>
#include <media/videobuf2-dma-contig.h>
https://github.com/raspberrypi/linux/bl ... ra.c#L1909
q->mem_ops = &vb2_vmalloc_memops;
Only one of those includes should be present, but we appear to still be on vmalloc so all is OK at present.
paul433
Tue Feb 13, 2018 3:03 am
We have been doing a lot of reboot testing, our regular kernel which is compiled nearly identical to the rpi kernel now seems to be pretty stable, with well over 1000 reboot cycles with no kernel panics. However the PREEMPT and PREEMPT_RT kernels are still showing the crash as posted above. Couple of observations
Running Headless or putting dwc_otg.fiq_enable=0 and dwc_otg.fiq_fsm_enable=0 on the command line also reduce/eliminate the kernel panics.
Return to “Advanced users”
