RomanMeR
Exact moment in the past when throttling occured
Fri Oct 27, 2017 5:33 pm
Hello! It is said in this post that using the
vcgencmd get_throttled
command it's possible to know that under-voltage condition, ARM frequency capping or throttling has occured since RPi boot. Is it possible to find by some (built-in in Raspbian) means the exact moment in the past when such situation took place?
Re: Exact moment in the past when throttling occured
Fri Oct 27, 2017 8:05 pm
I tried running four copies of
#include <stdlib.h>
#include <stdio.h>
void main(int argv, char * argc[]){
        int loop = 1;
        long cnt = 0;;
        while (loop) {
                cnt++;
as an ugly CPU soaker to get my RPi3B running hot and throttled. There's no external information in /var/log/messages or /var/log/syslog or dmesg output when throttling happens. So all you can do is, crudely, run a vgcencmd get_throttled command periodically and log the time when the throttled bit changes.
This is a doctor free zone.
sora03
Thu Nov 02, 2017 11:15 am
you can write a python or bash script to execute the vgencmd get_throttled command with date so you will know what time/date it occured. you can run the script it crontab for about 1 minute.
example bash script: checkthr.sh
#!/bin/bash
date >> /home/pi/THROTTLED.log
vcgencmd get_throttled >> /home/p/THROTTLED.log
do not forget to write exec permission:
 chmod +x ./checkthr.sh'
Edit crontab: $ crontab -e
add:
*/1 * * * * /home/pi/checkthr.sh
that script will run everyminute. you can also use the rpiburn tha will test your PSU
$git clone https://github.com/ronny-nilsson/rpiburn
$ cd rpiburn && make && sudo make install
to test PSU
$ sudo rpiburn
FLOSS enthusiast, Debian user (linux-libre)
jahboater
Thu Nov 02, 2017 11:36 am
For testing, use this to very quickly guarantee throttling:-
wget https://raw.githubusercontent.com/ssvb/cpuburn-arm/master/cpuburn-a53.S
gcc -o cpuburn-a53 cpuburn-a53.S
./cpuburn-a53
itsmedoofer
Wed Nov 08, 2017 12:33 pm
If you just want to get things nice and hot simply put this into bash:
for i in 1 2 3 4; do while : ; do : ; done &  done
jahboater
Wed Nov 08, 2017 5:19 pm
Thats pretty clever! And it uses all four cores.
But it only got my Pi3 to about 70C after a couple hours and it didn't throttle.
Cpuburn-a53 uses the NEON SIMD unit instead which is very powerful.
I believe it is quad issue (unlike the ARM stuff), so I suspect that with some clever coding it can potentially do:-
4 cores x quad issue (4 insns) x 4 lanes = 64 float operations per cycle.
It does get my Pi3 above 80C within a minute or so (and starting to throttle).
Return to “Advanced users”
