bobjohncat
Dual Boot on USB - 2 identical OSs - failover OS
Mon Oct 16, 2017 11:23 am
I would like to have two identical OSs, Rasp Stretch Lite, as a safety/update feature for unmanned Pis.
So if I had stored on 2 partitions on a USB stick
OS_A
OS_B
Have it boot OS_A and use this OS.
In the future I want to upgrade the OS, lets say instead of running apt-get update and relying on this process, I could get OS_A to download a compressed image, uncompress it to the partition of OS_B, once its done, update the boot file to point to this OS_B, it reboots and load OS_B. If OS_B is successful then carry on using that. Obviously in the future I can do the same upgrade but back to OS_A.
Couple of questions
1) Is my logic sound with this idea?
2) Any ideas how I can write a fail back script, so lets say OS_A just uncompressed a new OS to OS_B, changes the boot file to point to OS_B and reboots. If OS_B fails to boot then how can I update the boot file to go back to OS_A
Thanks in advance for any thoughts
DorianAtExtensia
Re: Dual Boot on USB - 2 identical OSs - failover OS
Wed Oct 18, 2017 4:24 pm
wow, I just posted a bootloader request for this today and just saw your post here.
my post is still pending moderator approval
but I asked if they could implement a feature similar to u-boot's bootcount/altbootcmd feature.
I've been able to get u-boot to work with this A/B/Recovery partition scheme using the regular raspberry pi's.
but I would prefer having built in bootloader support than using u-boot.
in a nutshell I recommended a bootcount.txt file in the fat boot partition that has:
bootcount=0
maxbootcount=3
altbootconfig=config2.txt
the bootloader can update the bootcount an the os can reset it to zero
if the bootcount exceeds maxbootcount use the config file from altbootconfig instead of the default config.txt
probably also need an altbootcmd too for the cmdline.txt
-dorian
bobjohncat
Thu Oct 19, 2017 10:45 pm
Many thanks for the reply, really helpful and will look into this!
Return to “Advanced users”
Who is online
Users browsing this forum: Bing [Bot] and 17 guests
