SurferTim
Re: Communicating between sense hats
Mon Oct 16, 2017 4:33 pm
bensimmo wrote:
Mon Oct 16, 2017 4:14 pm
Surfertim,
If you have the raspbian desktop you can install, if not already there, the SenseHat emulator and use that, just import sense_emu instead.
It is designed around Python3 so no need to switch to python2
Thanks for the info, but I was concerned only with getting the python script to work.
hawkesley
Tue Oct 17, 2017 10:14 am
I can get Hello World on the web page.
However if I add the sense hat code , Hello World is not displayed or the Hello World from the sense hat.
So I am wodering if the proposed action in the program for the sense hat is not possible.
To be clear, this code does not work
#!/usr/bin/python3
from sense_hat import SenseHat
sense = SenseHat()
sense.show_message("Hello World")
#print("Hello World")
This code displays Hello World in the web page.
#!/usr/bin/python3
# sense_hat import SenseHat
# = SenseHat()
#sense.show_message("Hello World")
SurferTim
Tue Oct 17, 2017 10:19 am
Change this
#!/usr/bin/python3
To this
#!/usr/bin/python
bensimmo
Tue Oct 17, 2017 11:01 am
Change this
#!/usr/bin/python3
To this
#!/usr/bin/python
I have to ask, why (if it works)? Given SenseHat (python) is designed around Python3 (and then to be backwards compatible with Python2)
Nothing in that code is Python2 code only.
SurferTim
Tue Oct 17, 2017 11:06 am
bensimmo wrote: I have to ask, why (if it works)? Given SenseHat (python) is designed around Python3 (and then to be backwards compatible with Python2)
Here is why:
With python it runs but reports a "no device" error because I don't have a sense hat.
With python3, it doesn't run. It fails. It aborts when it reaches the SenseHat() function call.
Edit: Are you testing this code with an Apache server using the php code previously posted?
hawkesley
Tue Oct 17, 2017 12:20 pm
Hi
Yes I am using the php code I previously posted on my Apache server.
$output=shell_exec("/var/www/html/wp-content/themes/twentysixteen/sense-test.py");
echo $output;
SurferTim
Tue Oct 17, 2017 12:21 pm
hawkesley wrote: Hi
echo $output;
...and you changed the first line in your python script to python instead of python3?
Edit: We may have a language problem here. How about this?
python = success
python3 = fail
python = good
python3 = bad
hawkesley
Tue Oct 17, 2017 12:45 pm
With the sense hat code commented out, either python or python3 work.
With the sense hat code not commented but Hello World commented,
with either python or python 3 there is no output.
SurferTim
Tue Oct 17, 2017 12:52 pm
Here is my /home/pi/python/test.py script
#!/usr/bin/python
try:
   sense = SenseHat()
except Exception as e:
        print "ERROR!"
        print(e)
#       exit()
print "<br>end of my python script"
Here is my index.php code
<html>
<body>
PYTHON TEST<br>
<?php
$output = shell_exec('/home/pi/python/test.py');
echo $output;
</body>
</html>
Here is the output using Chrome:
PYTHON TEST
ERROR! Cannot detect RPi-Sense FB device
Edit: If I change the first line to python3 in the python code, I get this
PYTHON TEST
hawkesley
Tue Oct 17, 2017 1:41 pm
Hi
I have replicated your code and tried the shebang with python and python3 and I get PYTHON TEST.
So a bit stuck.
For the record my test.py is in a folder SH-test which is in /var/www/html/
I made test.py chmod +x
Python test.py
#!/usr/bin/python
try:
   sense = SenseHat()
        print "ERROR!"
        print(e)
#       exit()
PHP sh.php (its php because Apache is set to serve php)
html>
<body>
PYTHON TEST<br>
<?php
$output = shell_exec('/var/www/html/SH-test/test.py');
echo $output;
</body>
</html>
SurferTim
Tue Oct 17, 2017 1:55 pm
I entered your directories and files exactly as you posted.. My server is at 192.168.1.3, and When I entered this in the address bar
http://192.168.1.3/sh.php
I got this
PYTHON TEST
hawkesley
Tue Oct 17, 2017 3:18 pm
I still get the same result.
Maybe its because I do have a sense hat attached.
Maybe I will detach it and try.
Is your result not the result you would expect if you did not have a Hat or do you think my py script is not running yet it seems to be.
bensimmo
Tue Oct 17, 2017 3:53 pm
If you had a SenseHAT you wouldn't get the error.
test.py wouldn't work in Python3 anyway, probably why it doesn't work.
It would fail on the print statements.
-- I'm following but cannot test as I have no wordpress setup.
But all I can see is it's working, just the SenseHat display is not triggering.
So you get no error either way.
Is there a permission problem with running the SenseHat from there. Perhaps grab the AstroPi/Sense-hat section of the forum?
You are getting Hello World with your code. It could just be the SenseHat not working as wanted.
I assume it works if you run it from IDLE's/Thonny on the Pi itself from a normal folder.
hawkesley
Tue Oct 17, 2017 4:28 pm
will do
thanks
bensimmo
Tue Oct 17, 2017 5:00 pm
will do
thanks
As a test for me
https://trinket.io/python/484a93f4e8
The code works fine and scroll text and shows just <br>end of my python script
as expected
If I force an error, say change to sense = Sense6Hat()
I get
ERROR!
NameError: name 'Sense6Hat' is not defined on line 6
force the error in your code and see what it returns
So the "Python code" is fine, in my opinion.
Just the way it's being triggered and how that works or allows the sesehat to work.
Does the 'user group' have access to all that the SenseHat needs (probably I2C mainly,)
hawkesley
Wed Oct 18, 2017 9:51 am
Ok I replicated your script and I get the same result, so as you say I think the code is fine.
I have now run my SH-test with test.py and get this error
PYTHON TEST
ERROR! [Errno 13] Permission denied: '/var/www/.config'
So it is permissions but how to give Apache (www-data) the right permissions?
Code fro completeness
sh.php
<html>
<body>
PYTHON TEST<br>
<?php
echo $output;
</body>
</html
test.py
#!/usr/bin/python3
try:
   sense = SenseHat()
        print ("ERROR!")
        print(e)
#       exit()
print ("<br>end of my python script")
bensimmo
Wed Oct 18, 2017 10:52 am
I don't know own the correct answer to that, surfertim might though?
SurferTim
Wed Oct 18, 2017 12:05 pm
I have no file 'var/www/.config' in my install. Do you?
cd /var/www
ls -a
Edit: I installed apache2 and php5 from the repository. I didn't need to install sense hat. It was installed by default. Same with you?
hawkesley
Wed Oct 18, 2017 12:31 pm
Yes I didnt need to install sense hat.
I will investigate /var/www/config.
Its odd because the path is /var/www/html/SH-test/
In html there is a config file for wordpress of course.
SurferTim
Wed Oct 18, 2017 12:36 pm
Because of where in the python script you are getting that error, it is an error generated by the SenseHat() call. Maybe it expects a .config file there. ??
Return to “Advanced users”
Who is online
Users browsing this forum: No registered users and 13 guests
