aeromaxx
adding new users to raspbian stretch lite
Wed Sep 20, 2017 1:33 pm
I'm looking to add a new user to my raspberry pi running raspbian stretch lite.
I followed this guide to attempt to secure my pi, I've only done down to the SSH section and not gone further than that yet.
https://makezine.com/2017/09/07/secure- ... attackers/
I've made some alterations to the following files :-
/etc/bash.bashrc
/etc/screenrc
/home/pi/.bashrc
/etc/skel/.bashrc
When I now login with pi over ssh, I get the following prompt.
[pi@pi ~]$
When I log with the new user I have created I get the following prompt instead.
For the new user $PS1 and $PROMPT_COMMAND are both blank and not set as they should be as specified in the .bashrc file.
The new user's .bashrc file is the same as the pi users .bashrc file.
After making changes I have rebooted, but still the prompt is the same as before.
Edit:
I have found something interesting which is why I now believe that ~/.bashrc isn't being loaded on login.
[pi@pi ~]$ echo $BASH_VERSION
4.4.12(1)-release
[pi@pi ~]$
gkaiseril
Re: adding new users to raspbian stretch lite
Wed Sep 20, 2017 2:58 pm
Within the "/etc" directory there should be a "./skel" directory that is used as a skeleton directory structure when a new user is added. Making changes to the files in this directory should carry over to any new user being added.
f u cn rd ths, u cn gt a gd jb n cmptr prgrmmng.
aeromaxx
Wed Sep 20, 2017 3:38 pm
I have made the changes to the files in that directory, and the updated files are in the new users home directory, but the prompt isn't the same as the default pi user.
As mentioned the $PS1 and $PROMPT_COMMAND bash variables contain nothing when echo'ed.
The pi user and the newly created user's files in the home directory are identical, but the prompts are different.
sparkyhall
Thu Sep 21, 2017 4:58 pm
It looks like you have not set the default shell for your new user to bash, to do this enter the following:
sudo usermod -s /bin/bash <your new user name>
aeromaxx
Thu Sep 21, 2017 5:12 pm
Yes partially correct, for some reason when I created the user, the useradd command didn't create the user with the default shell it should have done according to the /etc/adduser.conf file.
I had thought I had posted this earlier, but just noticed I hadn't clicked submit.
I have worked out what the issue was.
When running a useradd command such as
useradd "testuser" --groups "sudo" --create-home
The newly created user has no shell, this what is in the /etc/passwd file
testuser:x:1001:1001::/home/testuser:
When compared with the pi user in the same /etc/passwd file.
pi:x:1000:1000:,,,:/home/pi:/bin/bash
Also looking at the /etc/adduser.conf file (see below) suggests that the default shell is /bin/bash
# /etc/adduser.conf: `adduser' configuration.
# See adduser(8) and adduser.conf(5) for full documentation.
# The DSHELL variable specifies the default login shell on your
# system.
DSHELL=/bin/bash
Return to “Advanced users”
