NavyIsland
CAN bus communication to and from a Pi
Thu Sep 14, 2017 8:36 pm
Hello, i am attempting to turn a Pi, model yet to be chosen, into a simple PLC using the can bus protocol.
Wondering if any pi supports can communication?
also, i am planing on using c++ as the programing language simply for execution speed. Wondering if anyone knows of any libraries that interpret can?
~Ben
djlegge
Re: CAN bus communication to and from a Pi
Fri Sep 15, 2017 1:20 pm
The usual way is to use a can controller (eg. MCP2515) connected by the SPI interface to the PI.
Example :
http://www.industrialberry.com/canberrydual-v2-1/
Can bus is supported in the Linux kernel by socketcan and appears as a network interface.
https://en.wikipedia.org/wiki/SocketCAN
https://www.kernel.org/doc/Documentatio ... ng/can.txt
There are also test / debugging programs for socketcan here :
https://github.com/linux-can/can-utils
There are also USB can interfaces available but when I last looked but they were much more expensive and intended to be used with Windows PC's.
I hope this helps get you started.
Darren.
PeterO
Fri Sep 15, 2017 1:32 pm
SK Pang does a CANBUS HAT.
http://skpang.co.uk/catalog/pican2-canb ... -1475.html
I've used one to communicate with PIC18F devices.
PeterO
Return to “Advanced users”
