lucas.sun
Multiple pi cameras
Thu Jul 13, 2017 5:15 pm
Hi all,
I want to capture, collect, and merge all photos from multiple pi cams (e.g., 20 cams) while triggering a GPIO button or any input event. Could someone share what it will be a nice way to make this work? Basically, the requirement is to get all photos back to a RPi or a computer for the further processing. What will be a good data transfer mechanism/ protocol ? Many thanks!
ghans
Re: Multiple pi cameras
Thu Jul 13, 2017 5:32 pm
compoundpi might be an useful building block for your project.
ghans
lucas.sun
Fri Jul 14, 2017 2:12 am
ghans wrote:compoundpi might be an useful building block for your project.
ghans
Thanks a lot! I will look into this.
Gavinmc42
Fri Jul 14, 2017 3:57 am
Zero's Plus USB hubs.
Boot Zero's from USB so no SD card needed.
Probably will need GPIO triggers, not sure if the is a USB equivalent of the UDP broadcast?
I'm dancing on Rainbows.
ghellquist
Sat Jul 15, 2017 9:13 am
You will need to think about how much "jitter" you can accept in when the pictures are taken. For extreme precision, say below milliseconds, I am not sure you can make the standard Pi camera to react that fast. This will influence how you trigger the picture processes in the network of Pi-s. Depending on your requirements you could connect the Pi-s over a wifi-network, over wired internet or using a separate hardware line for the triggering.
/Gunnar
drgeoff
Sat Jul 15, 2017 5:36 pm
Gavinmc42 wrote:Boot Zero's from USB so no SD card needed.
AIUI that is not possible.
(And we don't need the grocers' apostrophe, thankyou.)
Sat Jul 15, 2017 5:46 pm
Actually it may be possible. The CM can be booted over a USB link with code that turns it into a USB storage device using the SD card. The same code works (I think) for a Zero. I think there is similar code that can put the zero into USB boot mode.
I feel your pain.
Return to “Advanced users”
