twem
Munin Temperature Monitoring
Sat Sep 29, 2012 9:43 pm
I installed Munin on my PI today and wanted to see if i could get it to monitor the temperature.
I could not find a conclusive guide on how to set this up so i thought i would post my notes in case it helped anyone else.
Install munin as per normal.
Within the munin plugins folder
/etc/munin/plugins
Write a new file, I called mine "temp"
Copy the below into the file
#!/bin/sh
case $1 in
   config)
        cat <<'EOM'
graph_title Temperature
graph_vlabel temp in C
graph_args --base 1000 -l 0
graph_category Temperature
temp.label Temperature
temp.warning 60
temp.critical 85
EOM
        exit 0;;
esac
temp=`sudo /opt/vc/bin/vcgencmd measure_temp | cut -d"=" -f 2 | cut -d"'" -f 1`
echo "temp.value "$temp""
Then you need to change the sudoers file to allow the command to run, i kept getting
VCHI initialization failed
for a long time before i worked this out.
sudo visudo
Change the below
#includedir /etc/sudoers.d
pi ALL=(ALL) NOPASSWD: ALL
to
nobody ALL=(ALL) NOPASSWD: /opt/vc/bin/vcgencmd
To save and quit
Ctrl+x
y
Enter
its now ready to test
munin-run temp
It should display the current temperature of your pi, after 5 min the new graph should show up in the munin web screens.
Code snippets are pulled from lots of different sites on the web I would give credit but I have forgotten where it all come from
Commends, Criticism, Improvements are all welcome
val
Re: Munin Temperature Monitoring
Sun Nov 04, 2012 3:09 pm
Hey,
just wanted to tell you that the the usage of sudo + sudoers is not really the way to do things for munin-node.
You can specify the user under which the script is run in the plugin configuration.
Create a file with the plugin name: /etc/munin/plugin-conf.d/temp
Put this inside the file:
[ptemp]
user root
Cheers,
Val
val
Sun Nov 04, 2012 3:57 pm
val wrote:
[ptemp]
user root
Woops.. copy+paste error (my plugin was named ptemp). This is the correct content of the file:
[temp]
user root
sanchomuzax
Tue Apr 23, 2013 11:44 am
Can you help me?
What is it? I don't know that "this by eating or drinking". :mrgreen:
What is the problem?
$ munin-run temp
# Unknown service 'temp'
List of folder:
Thank you for your help!
karlos13
Wed May 01, 2013 3:52 am
I get the same thing, The standard graphs work though.
Its like the plugin is not enabled and it does not show up when I do the munin configure command.
This one also does not work either:
https://github.com/perception101/pisense
I get the impression I'm doing something wrong or is the plugin amiss?
EDIT: A permissions change on the /cache/plugins new plugin enabled it and all is good
Tony2k
Sun May 26, 2013 10:26 pm
karlos13 wrote: EDIT: A permissions change on the /cache/plugins new plugin enabled it and all is good
Hi karlos,
I have the same problem with the pisense plugin... where did you change the permissions exacly? cant find cache/plugins
karlos13
Mon May 27, 2013 12:28 am
Add the plugin here: /usr/share/munin/plugins and make it 0755 (?)
Then add to etc/munin/plugin conf
[pisense_*]
user root
Then run the link command and that should be it.
ln -s /usr/share/munin/plugins/pisense_ /etc/munin/plugins/pisense_
From there I think if you have success running
munin-node pisense
the new plugin will be seen by the 5 minute cron, otherwise the /var/munin log is helpful.
Tony2k
Mon May 27, 2013 10:39 am
log:
2013/05/27-12:19:08 [3088] Error output from pisense_temp:
2013/05/27-12:19:08 [3088]      /etc/munin/plugins/pisense_temp: 5: /etc/munin/plugins/pisense_temp: Syntax error: newline unexpected
2013/05/27-12:19:08 [3088] Service 'pisense_temp' exited with status 2/0.
2013/05/27-12:19:08 [3088] Error output from pisense_:
2013/05/27-12:19:08 [3088]      /etc/munin/plugins/pisense_: 5: /etc/munin/plugins/pisense_: Syntax error: newline unexpected
2013/05/27-12:19:08 [3088] Service 'pisense_' exited with status 2/0.
2013/05/27-12:19:09 [3088] Error output from pisense_volt:
2013/05/27-12:19:09 [3088]      /etc/munin/plugins/pisense_volt: 5: /etc/munin/plugins/pisense_volt: Syntax error: newline unexpected
2013/05/27-12:19:09 [3088] Service 'pisense_volt' exited with status 2/0.
2013/05/27-12:19:09 [3088] Error output from pisense_clock:
2013/05/27-12:19:09 [3088]      /etc/munin/plugins/pisense_clock: 5: /etc/munin/plugins/pisense_clock: Syntax error: newline unexpected
2013/05/27-12:19:09 [3088] Service 'pisense_clock' exited with status 2/0.
2013/05/27-12:19:14 Pid_file already exists for running process (3088)... aborting
the path I followed:
sudo chmod 755 /usr/share/munin/plugins/pisense_
sudo chown root:root /usr/share/munin/plugins/pisense_
sudo nano /etc/munin/plugin-conf.d/munin-node
add
[pisense_*]
user root
ln -s /usr/share/munin/plugins/pisense_ /etc/munin/plugins/pisense_clock
ln -s /usr/share/munin/plugins/pisense_ /etc/munin/plugins/pisense_volt
ln -s /usr/share/munin/plugins/pisense_ /etc/munin/plugins/pisense_temp
sudo /etc/init.d/munin-node restart
I have no idea why this does not work... :(
sanchomuzax
Mon May 27, 2013 11:20 am
Is it possible that you running more than once the munin service?
Test it:
service munin-node status
If "yes", then stop the services, and restart again.
Or test it with it:
sudo munin-run pisense_clock config
Tony2k
Mon May 27, 2013 12:07 pm
[email protected] /usr/share/munin/plugins > service munin-node status
[ ok ] Munin-Node is running (PID: 14985).
[email protected] /usr/share/munin/plugins > sudo munin-run pisense_clock config
sanchomuzax
Mon May 27, 2013 12:24 pm
I think that your plugin configuration is bad.
Because the munin-run on pisense_clock config should be the following:
graph_title Raspberry Pi clock frequencies
graph_vlabel herz
graph_category sensors
clockarm.label arm clock Frequency
clockarm.min 0
I'm not linux expert, but is it possible that you and I using different root privilege. My default root user the "pi", not the root. I'm not using the "root", because the "pi" is the root, as you can see the sudo on my examples.
I'm using the temp monitor also and it's working correctly:
My file privileges:
and
The all symlinks are linking to "/usr/.../pisense_":
Tony2k
Mon May 27, 2013 1:15 pm
I also use the default user "pi", but I was in with "sudo -s" so i dont have to type sudo again and again.
My privileges seems equal to yours:
[email protected] /etc/munin/plugins $ ls -l pis*
lrwxrwxrwx 1 root root 33 Mai 27 12:17 pisense_ -> /usr/share/munin/plugins/pisense_
lrwxrwxrwx 1 root root 33 Mai 16 23:44 pisense_clock -> /usr/share/munin/plugins/pisense_
lrwxrwxrwx 1 root root 33 Mai 16 23:45 pisense_temp -> /usr/share/munin/plugins/pisense_
lrwxrwxrwx 1 root root 33 Mai 16 23:44 pisense_volt -> /usr/share/munin/plugins/pisense_
[email protected] /usr/share/munin/plugins $ ls -l pis*
-rwxr-xr-x 1 root root 53542 Mai 17 00:39 pisense_
braegel
Thu Jul 05, 2018 7:59 pm
I had problems with
I could resolve by putting the "temp" file in
activating the plugin by
ln -s /usr/share/munin/plugins/temp /etc/munin/plugins/temp
and allowing x-ecution by
chmod +x /usr/share/munin/plugins/temp
Now i got:
[email protected]:~# munin-run temp
temp.value 53.2
Hope that helps.
Return to “Advanced users”
Who is online
Users browsing this forum: No registered users and 22 guests
