xavier666
Control Linux PC by connecting a Pi to it via USB
Mon Jul 03, 2017 11:06 pm
I have a PC A whose eth0 port is already in use inside a private topology which does not have access to the Internet.
It does not have any Wifi interfaces also
What I want to do is to connect a Pi P to A via USB.
Then, using my controller PC B, I want to ssh to P. From P, I want to control A by using ssh over USB.
I have seen that the reverse is possible
 [eth]         [ssh over USB]
B ----------> P ----------> A
Is this possible?
itimpi
Re: Control Linux PC by connecting a Pi to it via USB
Tue Jul 04, 2017 4:46 am
You do not mention what model of Pi?
For this to work you are going to need the Pi to be able to drive the USB port in ‘gadget’ mode. As far as I know only the pi0, Pi0W and Pi model A can do this.
rpdom
Tue Jul 04, 2017 5:08 am
itimpi wrote:For this to work you are going to need the Pi to be able to drive the USB port in ‘gadget’ mode. As far as I know only the pi0, Pi0W and Pi model A can do this.
It won't work with either of those because they don't have an ethernet connection, and you can't add a USB ethernet dongle when in gadget mode.
It could possibly be done with a Pi B/B+/2B/3B and a USB-net cable.
Tue Jul 04, 2017 5:22 am
USB-NET Cable may be the answer, see: viewtopic.php?f=36&t=131042
Asus ChromeBox 3 Celeron is my other computer.
ghans
Tue Jul 04, 2017 7:28 am
There are WiFi shields for the Pi0 based on SPI and the ESP8266. Not fast , but they work.
ghqns
B.Goode
Tue Jul 04, 2017 7:29 am
Why not simply connect all 3 devices to the same shared private network infrastructure?
Or is there an implication that controller PC B is outside of the private network?
xavier666
Tue Jul 04, 2017 11:09 am
itimpi wrote:You do not mention what model of Pi?
RPi 3 Model B
xavier666
Tue Jul 04, 2017 11:11 am
B.Goode wrote:Why not simply connect all 3 devices to the same shared private network infrastructure?
You are indeed correct. Controller B is outside the private network.
I can, however, connect to the Pi via wlan. Using wlan, I want to ssh into the Pi, through which, I want to ssh to PC A
Tue Jul 04, 2017 11:15 am
RPi 3 Model B
The RPi 3B does not support USB "Slave" Mode it is a hardware limitation.
If you can not use WiFi, Ethernet or Bluetooth then as I linked above USBNET Cable.
B.Goode
Can you make a cabled Ethernet connection from Pi P to the private network?
xavier666
Tue Jul 04, 2017 11:21 am
RPi 3 Model B
Ok thanks!
Tue Jul 04, 2017 5:36 pm
ghans wrote:There are WiFi shields for the Pi0 based on SPI and the ESP8266. Not fast , but they work.
ghans
What's slow about this one https://redbear.cc/content/blog/pi-zero-iot-hat/ ? Got one of those on my RPi2B, it fits a Zero.
I'll do your homework for you for a suitable fee.
pcmanbob
Tue Jul 04, 2017 6:58 pm
Breaching a private network like this and allowing access from the internet is risky and in a work or education environment could get you in a lot of trouble with the system administrator.
You have been warned your job / university place could be at risk here if this is not your own network
Return to “Advanced users”
