mvdm
Global Alsamixer equaliser
Sun Jul 02, 2017 7:33 pm
Hi all,
i have a RPI3 running Jessie Pixel, the Pi3 has a HifiBerry AMP attached. The amp works, and through a lot of trial and error I finally managed to get the alsamixer equaliser to work some of the time.
To make it work I did the following:
$ sudo nano /boot/config.txt
#dtparam=audio=on
$ sudo nano /etc/modprobe.d/alsa-blacklist.conf
blacklist snd_bcm2835
$ sudo nano /etc/asound.conf
pcm.!default {
 type plug
 slave.pcm plugequal;
ctl.!default {
 type hw card 0
ctl.equal {
 type equal;
pcm.plugequal {
 type equal;
 slave.pcm "plughw:0,0";
pcm.equal {
 type plug;
I can test it with "$ speaker-test -c2 -twav" and my equaliser has an effect and works also when i play music through my RTL-SDR "$ rtl_fm -g 50 -f 101M -M wfm -s 180k -E deemp | play -r 180k -t raw -e s -b 16 -c 1 -V1 - lowpass 16k"
But it will not work for chromium, or pulseaudio bluetooth connection. The audio plays, but with no EQ.
I tried the following:
$ sudo nano ~/.asoundrc
pcm.!default {
 type plug
ctl.equal {
 type equal;
pcm.plugequal {
 type equal;
But the result was that the sound test and FM radio (RTL-SDR) was still working, but chromium and pulse audio was no longer producing any sound output.
How can i configure a global equaliser that will just work for everything? Thanks in advance
Return to “Advanced users”
