jeebo
Can no longer connect to Pi with Hostname
Fri May 26, 2017 2:03 pm
Hi Guys,
For some reason I can no longer connect to my Pi over the LAN based on the WINS Hostname.
Its set to FPHS, its on the same LAN / Subnet but the name cannot be found on the network. even rebooting both pi and laptop it fails to find the name still, though I can access the Pi via its IP in the same way.
mattmiller
Re: Can no longer connect to Pi with Hostname
Fri May 26, 2017 3:17 pm
Best thing is to install Bonjour on your Win machine
WINS name lookup is not the most reliable
Mind you, switching router on and off might be temp fix
SurferTim
Sat May 27, 2017 12:28 pm
If the hostname is FHPS, then you should use FHPS.local. Is that what you are using?
I tested it with my hostname using Ubuntu. Worked ok.
Sat May 27, 2017 2:42 pm
mattmiller wrote:Best thing is to install Bonjour on your Win machine
ALL supported & supportable versions of Windows have mDNS (multicast DNS aka zeroconf networking aka Bonjour) support built in. It would only be folks running XP or Win7 that need anything special like iTunes to get mDNS.
I've never installed iTunes (never needed it, I've never had any Apple device) and mDNS works for me.
This is a doctor free zone.
mattmiller
Sun May 28, 2017 1:03 pm
Ta for info :)
I didn't realise that MS had done this with Win10
I'm still running Win98SE myself :)
jeebo
Thu Jun 08, 2017 1:00 pm
Thanks all, oddly it used to work fine just running FPHS, not sure why it isnt anymore though. Never needed to run ".local" on the end of it.
Return to “Advanced users”
