jeebo
rpi-clone on Jessie
Thu May 25, 2017 8:34 am
Hi Guys,
I am trying to get rpi-clone working on Jessie to try and backup my SD Card whilst its actively running.
I have tried to clone the github repository, which failed, tried to download the rpi-clone with wget, which failed, and now I am just feeling a tad lost as to why its not working!
Any ideas? I expect I have missed the simple or obvious?
B.Goode
Re: rpi-clone on Jessie
Thu May 25, 2017 9:02 am
jeebo wrote:I have tried to clone the github repository, which failed, tried to download the rpi-clone with wget, which failed
One simple/obvious thing would be to explain exactly how the steps you attempted failed, preferably by posting the resulting error messages if any.
jeebo
Thu May 25, 2017 9:09 am
I can completely agree, however, I have none.
The failure is that I couldnt even get it to start...
I tried the following commands, all of which error saying they dont exist.
wget https://github.com/billw2/rpi-clone (file downloaded)
ls (returned desktop,docs,downloads,etc and "rpi-clone"
$ unzip rpi-clone-master.zip
$ cd rpi-clone-master
$ cp rpi-clone /usr/local/sbin
$ git clone https://github.com/billw2/rpi-clone.git
$ cd rpi-clone
Perhaps I am following release notes rather than an idiot proof tutorial, I dont know, but I cannot even get the process to start.
The other method I am trying is this:
sudo su
cat /etc/fstab
dd if=/dev/mmcblk0p2 of=/dev/sda
So far its working away, however I would have thought it needs to take both partitions, mmcblk0p1 and 0p2, and put them both into the same image, as I get the feeling, if I was to swap the sda SD Card after this completes, and replace it with the 0px card in the pi right now, it wont boot?
jeebo
Thu May 25, 2017 10:53 am
as I expected.
sudo su
cat /etc/fstab
failed running it on its own, however I am not sure this can be ammended to move 0p1 to sda1, so will give that a try!
kusti8
Thu May 25, 2017 12:16 pm
You're downloading the github location as html. You need to clone the repository. It gives instructions in the README.
$ cd rpi-clone
B.Goode
Thu May 25, 2017 9:07 pm
Apart from a couple of places where use of root/superuser privilege is required, the documentation in the README at the https://github.com/billw2/rpi-clone repository appears to be correct for both of the alternative installation methods. Transcripts below.
Manual download and unzip:
[email protected] ~/jeebo $ wget https://github.com/billw2/rpi-clone/archive/master.zip
--2017-05-25 21:43:01--  https://github.com/billw2/rpi-clone/archive/master.zip
Resolving github.com (github.com)... 192.30.253.112, 192.30.253.113
Connecting to github.com (github.com)|192.30.253.112|:443... connected.
HTTP request sent, awaiting response... 302 Found
Location: https://codeload.github.com/billw2/rpi-clone/zip/master [following]
--2017-05-25 21:43:02--  https://codeload.github.com/billw2/rpi-clone/zip/master
Resolving codeload.github.com (codeload.github.com)... 192.30.253.120, 192.30.253.121
Connecting to codeload.github.com (codeload.github.com)|192.30.253.120|:443... connected.
HTTP request sent, awaiting response... 200 OK
Length: unspecified [application/zip]
Saving to: ‘master.zip’
master.zip              [ <=>                  ]   6.92K  --.-KB/s   in 0.004s
2017-05-25 21:43:02 (1.78 MB/s) - ‘master.zip’ saved [7082]
[email protected] ~/jeebo $ unzip master.zip
Archive:  master.zip
f961aee3f9816d345c2df335aa96b3907ee68b09
   creating: rpi-clone-master/
  inflating: rpi-clone-master/README.md
  inflating: rpi-clone-master/rpi-clone
[email protected] ~/jeebo $ cd rpi-clone-master/
[email protected] ~/jeebo/rpi-clone-master $ cp rpi-clone /usr/local/sbin
cp: cannot create regular file ‘/usr/local/sbin/rpi-clone’: Permission denied
[email protected] ~/jeebo/rpi-clone-master $ sudo cp rpi-clone /usr/local/sbin
[email protected] ~/jeebo/rpi-clone-master $ rpi-clone
Error: Error opening /dev/mmcblk0: Permission denied
rpi-clone needs to be run as root.
[email protected] ~/jeebo/rpi-clone-master $ sudo rpi-clone
usage: rpi-clone sdN {-f|--force-initialize} {-v|--verbose} {-x}
    Example:  rpi-clone sda
    -v - list all files as they are copied.
    -f - force initialize the destination partitions
    -x - use set -x for very verbose bash shell script debugging
    Clone (rsync) a running Raspberry Pi file system to a destination
    SD card 'sdN' plugged into a Pi USB port (via a USB card reader).
    rpi-clone can clone the running system to a new SD card or can
    incrementally rsync to existing backup Raspberry Pi SD cards.
    If the destination SD card has an existing fat16 partition 1 and a
    ext4 partition 2, rpi-clone assumes (unless using the -f option)
    that the SD card is an existing backup with the partitions
    properly sized and set up for a Raspberry Pi.  All that is needed
    is to mount the partitions and rsync them to the running system.
    If these partitions are not found (or -f), then rpi-clone will ask
    if it is OK to initialize the destination SD card partitions.
    This is done by a partial 'dd' from the running booted device
    /dev/mmcblk0 to the destination SD card /dev/sdN followed by a
    fdisk resize and mkfs.ext4 of /dev/sdN partition 2.
    This creates a completed fat16 partition 1 containing all boot
    files and an empty but properly sized partition 2 rootfs.
    The SD card  partitions are then mounted and rsynced to the
    running system.
    The SD card destination partitions will be mounted on /mnt/clone.
    A log will be written to /var/log/rpi-clone.log.
    It's better to avoid running other disk writing programs
    when running rpi-clone.
    Version 1.5
Clone github repository:
[email protected] ~/jeebo $ git clone https://github.com/billw2/rpi-clone.git
Cloning into 'rpi-clone'...
remote: Counting objects: 58, done.
remote: Total 58 (delta 0), reused 0 (delta 0), pack-reused 58
Unpacking objects: 100% (58/58), done.
Checking connectivity... done.
[email protected] ~/jeebo $ cd rpi-clone/
[email protected] ~/jeebo/rpi-clone $ sudo cp rpi-clone /usr/local/sbin
[email protected] ~/jeebo/rpi-clone $ sudo rpi-clone
    running system.
    Version 1.5
If basic operations such as wget, ls, cd and cp do not work correctly on your system then it may be corrupted in such a way that using a tool such as rpi-clone may be inappropriate since it even if it can be made to work it may simply create another copy of that corrupted system.
jeebo
Thu Jun 08, 2017 12:16 pm
Thanks all, I have been distracted and away recently so I need to try and get this up and running some point soon.
I know human error is a factor there as well, I just have to learn to work around that part!
Return to “Advanced users”
