Non-root GPIO access broken with 4.9 kernel on Pi1
Posted: Fri May 12, 2017 3:16 pm
by ziesemer
On a Raspberry Pi 1 Model B+, I ran normal OS updates (apt-get update/upgrade - no use of rpi-update / no "bleeding edge") - and the kernel was updated from 4.4.50+ to 4.9.24+. After this, my GPIO programs no longer work, failing with "Failed to add edge detection".
Minimal test case:
$ python
Python 2.7.9 (default, Sep 17 2016, 20:26:04)
[GCC 4.9.2] on linux2
Type "help", "copyright", "credits" or "license" for more information.
>>> import RPi.GPIO as GPIO
>>> def test(channel):
...   pass
>>> GPIO.setmode(GPIO.BCM)
>>> GPIO.setup(4, GPIO.IN)
>>> GPIO.add_event_detect(4, GPIO.BOTH, callback=test)
  File "<stdin>", line 1, in <module>
RuntimeError: Failed to add edge detection
$ uname -a
Linux raspberypi 4.9.24+ #993 Wed Apr 26 17:56:54 BST 2017 armv6l GNU/Linux
Edited to only need the default python, 2.7. The same results can be seen with python3. To use:
sudo apt install python3 python3-rpi.gpio
The same works without error when run as root (or with sudo), or on a Raspberry Pi 2 (running kernel 4.9.24-v7+). I remain a member of the "gpio" group, and all the related /dev objects I can find still appear to have the proper "root:gpio" permissions.
I have referenced Moving Linux kernel to 4.9.
For kicks, installing rpi-update and installing the latest kernel does not help, either:
Linux raspberrypi 4.9.27+ #997 Tue May 9 19:51:52 BST 2017 armv6l GNU/Linux
Doing nothing other than installing rpi-update and reverting back to 4.4 resolves the issue:
$ sudo rpi-update 52241088c1da59a359110d39c1875cda56496764
$ uname -a
Linux raspberrypi 4.4.50+ #970 Mon Feb 20 19:12:50 GMT 2017 armv6l GNU/Linux
Can anyone else reproduce? Should I open an issue at https://github.com/raspberrypi/linux/issues ?
(Also, is there a reason why "gpio" doesn't work with the search function on this forum?)
Re: Non-root GPIO access broken with 4.9 kernel on Pi1
Posted: Fri May 12, 2017 6:50 pm
by dom
I've tried your test on 4.9 kernel on both pi1 and pi3 and it worked for me. Anyone else tried?
Posted: Fri May 12, 2017 7:25 pm
by joan
Works okay for me on an original B and a Pi3.
Linux peter 4.9.27+ #997 Tue May 9 19:51:52 BST 2017 armv6l GNU/Linux
VERSION = '0.6.3'
Posted: Fri May 12, 2017 7:49 pm
by ziesemer
Thank you both. I'll continue to try to break this down and see what the difference is. Any suggestions as to some next things to look at and try?
I'll probably include an attempted clean install from https://www.raspberrypi.org/downloads/raspbian/ (2017-04-10 release date). Shows that it still comes with the 4.4 kernel, so I can test with and without the upgrade to 4.9.
FYI - I also found https://github.com/vitormhenrique/OctoP ... /issues/16 and https://github.com/raspberrypi/linux/issues/791 - both of which are reporting similar issues with 4.9.17.
Posted: Fri May 12, 2017 9:34 pm
by ziesemer
Re-applied the 4.9 kernel via rpi-update, broken again. Looks to be udev-related. The above code sample successfully created /sys/class/gpio/gpio4 - but everything is owned as root:root, not root:gpio. (Even then, all the files are 644, vs. 770 that I see on a working instance.) As such, I'm also now reproducing this with only sysfs, and completely ruling-out anything Python-related.
Following the April 5-10 discussion at https://github.com/raspberrypi/linux/issues/791, my /etc/udev/rules.d is certainly different between the broken Pi1:
$ ll 99-com.rules ; md5sum 99-com.rules
-rw-r--r-- 1 root root 506 Nov 21  2015 99-com.rules
1de39a305333e7c5bf0dca7ba5df9bdf  99-com.rules
... and and working Pi2 or Pi3:
-rw-r--r-- 1 root root 983 Mar 21  2016 99-com.rules
279f8967ca1013b96aa59416fd8557ab  99-com.rules
So especially given your tests - probably not specific to the version of the Pi, but more related to initial installed versions / upgrade paths...
Fix:
Following https://github.com/raspberrypi/linux/is ... -292901658, my non-working system did not have raspberrypi-sys-mods installed, while my working systems did. Installing this, and confirming to overwrite '/etc/udev/rules.d/99-com.rules' if prompted, resolved the issue. Be sure to remove any existing GPIO exports, or simply reboot - or existing exports will still have the broken permissions.
Posted: Sat May 13, 2017 12:49 pm
by dom
ziesemer wrote:my non-working system did not have raspberrypi-sys-mods installed, while my working systems did
Do you know why raspberrypi-sys-mods was missing? It should be installed by default on raspbian jessie.
Was it manually removed? Did you update from a non-supported version (wheezy)? Some other means of installing?
Posted: Sat May 13, 2017 1:09 pm
by fruitoftheloom
ziesemer wrote:Re-applied the 4.9 kernel via rpi-update, broken again. Looks to be udev-related. The above code sample successfully created /sys/class/gpio/gpio4 - but everything is owned as root:root, not root:gpio. (Even then, all the files are 644, vs. 770 that I see on a working instance.) As such, I'm also now reproducing this with only sysfs, and completely ruling-out anything Python-related.
Fix:
rpi-update should only be used under advisement it installs a Testing Kernel...
Raspbian Jessie all that is required is:
sudo apt-get update
sudo apt-get dist-upgrade
uname -a
Linux raspberrypi 4.9.24-v7+ #993 SMP Wed Apr 26 18:01:23 BST 2017 armv7l GNU/Linux
Posted: Sat May 13, 2017 1:36 pm
by ziesemer
fruitoftheloom wrote: rpi-update should only be used under advisement it installs a Testing Kernel...
Yes, but rpi-update is not relevant here. This was a concern with non-root GPIO access broken after the 4.9 kernel being applied by (only) apt-get dist-upgrade. I only used rpi-update to revert back to 4.4, and now back to 4.9 - using the specific commit hashes. Please correct me if otherwise, but I didn't see any way to revert or to re-upgrade using only apt-get.
That's a great question, isn't it? It was a clean Raspbian Jessie install. I'll see what history / logs are left on the card, or if I can reproduce if I still have the same downloaded disk image saved somewhere. My /var/log/apt/history.log* files go back to 2016-05-07, appear to contain my original installation / setups, and have no mention of raspberrypi-sys-mods until yesterday's install. Looking at the downloads I've saved, "2015-11-21-raspbian-jessie-lite.zip" must be what I had originally used here.
I'm not concerned about this for myself, but would like to continue to help to diagnose in case there is something that should be corrected here for anyone else having the same issue.
Posted: Sat May 13, 2017 3:56 pm
by ziesemer
ziesemer wrote: Looking at the downloads I've saved, "2015-11-21-raspbian-jessie-lite.zip" must be what I had originally used here.
Using a clean install from "2015-11-21-raspbian-jessie-lite.zip", raspberrypi-sys-mods was / is NOT installed by default:
[email protected]:~ $ apt show raspberrypi-sys-mods
Package: raspberrypi-sys-mods
Version: 20131021
Maintainer: Serge Schneider <[email protected]>
Installed-Size: 26.6 kB
Homepage: https://github.com/RPi-Distro/raspberrypi-sys-mods
Priority: optional
Section: admin
Download-Size: 2,094 B
APT-Sources: http://archive.raspberrypi.org/debian/ jessie/main armhf Packages
Description: System tweaks for the Raspberry Pi
 Various modifications to improve the performance or user experience.
[email protected]:~ $ dpkg -s raspberrypi-sys-mods
dpkg-query: package 'raspberrypi-sys-mods' is not installed and no information is available
Use dpkg --info (= dpkg-deb --info) to examine archive files,
and dpkg --contents (= dpkg-deb --contents) to list their contents.
[email protected]:~ $ cat /etc/os-release
PRETTY_NAME="Raspbian GNU/Linux 8 (jessie)"
NAME="Raspbian GNU/Linux"
VERSION_ID="8"
VERSION="8 (jessie)"
ID=raspbian
ID_LIKE=debian
HOME_URL="http://www.raspbian.org/"
SUPPORT_URL="http://www.raspbian.org/RaspbianForums"
BUG_REPORT_URL="http://www.raspbian.org/RaspbianBugs"
[email protected]:~ $ uname -a
Linux raspberrypi 4.1.13-v7+ #826 SMP PREEMPT Fri Nov 13 20:19:03 GMT 2015 armv7l GNU/Linux
Perhaps it should be considered a dependency of the 4.9 kernel / firmware update?
Posted: Sat May 13, 2017 4:00 pm
by DougieLawson
Why not do a clean install of 2017-04-10
Posted: Sat May 13, 2017 4:20 pm
by ziesemer
DougieLawson wrote:Why not do a clean install of 2017-04-10
Sure, that's always a "last resort" option. However, myself and others are experiencing this issue after an upgrade. The effort here was to at least explain the issue, and to hopefully help anyone else having the same problem.
Unless we are looking to suggest that certain upgrades (such as the 4.9 kernel upgrade) are not supported? Keep in mind, this system wasn't even an upgrade from wheezy. This also wasn't the result of trying to go "bleeding edge" with rpi-update, but simply running apt update/upgrade.
It seems that there may have been an assumption that raspberrypi-sys-mods would have been installed with any default jessie install. Seeing that this is not the case, this is maybe something that could easily be accounted for in the upgrade process - or at least shown as a notification during the upgrade process if an appropriate automated fix can't be applied without other concerns.
Posted: Tue Dec 12, 2017 11:24 pm
by PI_Stuart
I resolved my issue with this Link. The issue related to permissions on /dev/gpiomem
My system is a Model B upgraded from Wheezy to Jessie to Stretch.
Having checked that my user in this case "pi" was a member of group "gpio"
using $groups pi I when on to check permissions on /dev/gpiomem
$ ls -l /dev/gpiomem
crw------- 1 root root 244, 0 Dec 12 22:39 /dev/gpiomem
should be .......
crw-rw---- 1 root gpio 244, 0 Dec 28 22:51 /dev/gpiomem
So needed to change group to gpio......
$ sudo chown root.gpio /dev/gpiomem
Then change the permissions.
$ sudo chmod g+rw /dev/gpiomem
I have put this in forum as I found this before struggling on and finding the eventual solution.
Now just got node-red working turning LED on/off success!
Posted: Thu Dec 14, 2017 2:47 pm
by DougieLawson
The changing of permissions/ownership stuff for /dev/gpiomen is done in /etc/udev/rules.d/99-com.rules which is in raspberrypi-sys-mods package. You may want to reinstall that package.
Posted: Wed Jan 17, 2018 11:07 pm
by moth-paul
You say "The changing of permissions/ownership stuff for /dev/gpiomen is done in /etc/udev/rules.d/99-com.rules which is in raspberrypi-sys-mods package."
How does one reinstall reinstall that package?
Posted: Wed Jan 17, 2018 11:17 pm
by DougieLawson
sudo apt update; sudo apt install --reinstall raspberrypi-sys-mods;sudo reboot
