Hi everybody,
I need to benchmark some code I wrote on a Raspberry 3 board.
I tried the code mentioned in this post viewtopic.php?f=63&t=155498 but I am sure it didn't work because the BRCM on the Raspberry Zero is not the same as the one in the board I am using.
Can you please point me in a good direction so I can get this to work?
Thanks in advance for your time!
With my best regards,
Re: RPI3 - Cycle Count Register
Just a note: I am working with Raspbian with 32bits architecture for now!
I am still experiencing some trouble with this.
So far, this is where what I found:
1/ I implemented the following kernelside:
2/And from Userside, this is what I use to get the CCR value:
But the results with the timing tests I made are not very consistent and they do not show correct timing results.
Has anybody managed to make this work?
int enable_divider;
int do_reset;
int value;
enable_divider = 1;
do_reset = 0;
value = 1;
asm volatile ("mcr p15, 0, %0, c9, c14, 0" :: "r" (1));
// peform reset:
if (do_reset) {
value |= 2; // reset all counters to zero.
value |= 4; // reset cycle counter to zero.
if (enable_divider)
value |= 8; // enable "by 64" divider for CCNT
value |= 16;
// program the performance-counter control-register with mask constructed above
asm volatile ("MCR p15, 0, %0, c9, c12, 0\t\n" :: "r"(value));
// enable all counters:
asm volatile ("MCR p15, 0, %0, c9, c12, 1\t\n" :: "r"(0x8000000f));
// clear overflows:
asm volatile ("MCR p15, 0, %0, c9, c12, 3\t\n" :: "r"(0x80000001));
// Select individual counter (0)
asm volatile ("MCR p15, 0, %0, c9 , c12 , 5\t\n":: "r"(0x00));
// Write event (0x11 = Cycle count)
asm volatile ("MCR p15, 0, %0, c9 , c13 , 1\t\n":: "r"(0xD));
asm volatile ("MRC p15, 0, %0, c9 , c13 , 0\t\n": "=r"(cc));
It may be worth while to look through or ask on the bare metal forum.
From your other discussions you are doing this inside linux so it's out of my league.
However lets do the basic, the Pi3 has 4 cores so there are 4 performance registers (1 for each core) and you will require correct privileges to access them.
The Pi1 code works for me on the Pi3 in baremetal but I have got the other 3 cores parked and not in use and got the core down in normal service mode and set the non secure register access mode when I execute them. Sorry no idea how you do that under linux which is what you really need answered.
this is a bare metal forum.
Sorry for the late reply, I have put this aside for some time, and now I am back.LdB wrote:From your other discussions you are doing this inside linux so it's out of my league.
Looking at what you said, I configured the registers on the 4 cores and I am reading the cycle count register on the first core only with the command "tasket -c 0 ./test" which means execute the ./test program on core 0. My problem now is that for 1 second, I get values around 6482703. I have a fixed frequency of 700MHz, so 6482703 / 700 = 10 which means, if the measurment is correct, I have a factor of 10 and I don't know where it came from.
Have you encountered something like this?
